Go to Post I think your robot is lacking in non-threatening, huggable design. - Kevin Sevcik [more]
Unread 21-01-2013, 14:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Full Court shot
Nice video. That looks awesome. I assume you know there might be a pyramid on the field, so that's why you programmed in that little curve at the end....
Unread 21-01-2013, 15:13
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Full Court shot
Very impressive! Was it a one in a million type shot, or something more repeatable? Either way it looks really cool!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 21-01-2013, 23:14
bfk bfk is offline
FRC #2521
bfk is an unknown quantity at this point
Re: Full Court shot
It was about a one in five shot. With quite a bit of variance in the trajectory. Once the Frisbee goes past its vertical peak it becomes incredibly sensitive to even tiny variations from horizontal at launch. Well at least ours do.
We spent some more time balancing the wheel today and got it a bit straighter, but we're more concerned with shorter shots, that one was just too neat not to post.
Those wheels and the hubs have enough play to rattle anything apart. In today's tests one of the students said "It's much smoother, the floor isn't vibrating enough to make my legs numb."
Unread 22-01-2013, 13:20
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: Full Court shot
Hello bfk,
What motor are you using to drive the pneumatic wheel? The results look great!
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 22-01-2013, 13:42
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Full Court shot
Originally Posted by vinnie View Post
Hello bfk,
Answer is found in the Youtube Description:
Originally Posted by Youtube Video
Prototype shooter sinking the Frisbee at 57 feet. Single CIM running at about 90% power with AndyMark pneumatic wheel.
GitHub
Unread 22-01-2013, 13:45
vinnie's Avatar
Re: Full Court shot
Hello bfk,
Mentor (597) 2014
Unread 22-01-2013, 14:12
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Re: Full Court shot
I fear I'm opening up a can o' worms here, but does anyone think the long shots, i.e. from more than half court or so, will be affected by air currents/movement much? The shorter shots seem to not rely much on the disc floating. Is there much air movement inside a typical arena?
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 23-01-2013, 01:19
bfk bfk is offline
FRC #2521
Re: Full Court shot
I suspect that will be very venue dependent, unless they crank the bass way up on the PA, just to even things out between venues. Oops, maybe I shouldn't have said that.
Unread 22-01-2013, 14:26
Division by Pirates
Re: Full Court shot
We had that same problem, which was causing some variance in our shot accuracy. We might've had a chance of making some shots like you're own, but they would've been very rare. Very impressed by your work!
Unread 22-01-2013, 20:23
neaanopri neaanopri is offline
FRC #1389
neaanopri is an unknown quantity at this point
Re: Full Court shot
Out of curiosity, what gear ratio were you using?
Unread 22-01-2013, 21:22
dtengineering's Avatar
AKA: Jason Brett
Re: Full Court shot
Before I go all "safety mode", let me just point out that is a very cool shot and I'm pretty impressed. Okay... now its time for the tech inspector in me to express a concern...
I know this is just a prototype, and that you're probably already planning a safety shield for this shooter, but I think teams should be aware that not only are these wheels not designed to spin at high RPM, but that they store a significant amount of finger-ripping energy when they do.
It is much easier to build safety shields in to your design than to add them as part of tech inspection!
Thanks,
Jason
Unread 23-01-2013, 01:21
bfk bfk is offline
FRC #2521
Re: Full Court shot
Thanks,
Jason
Definitely a design consideration. I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way.
Unread 24-01-2013, 12:13
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Re: Full Court shot
Thanks,
Jason
This is definitely a valid point. One our team has considered as well. We are not using the AM Pneumatic Wheel but we attached "Shrapnel Guards" as far around our wheels as we could, so if the wheels wear out and fragment they won't fly out and hit anyone.
Unread 20-02-2013, 14:40
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: Full Court shot
Don't have a video yet but we were shooting above 90 percent into the 2 point goal from the feeder station. And able to get one load of 4 Frisbees every 10 to 15 seconds
Unread 22-01-2013, 21:31
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Full Court shot
That looks like the AM Pneumatic wheel. Were also using that, but it wobbles insanely. How did you manage to fix that? Yours looks pretty stable.
