Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 21-01-2013, 14:55
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Exporting inventor so it can be read for CAM
STEP files generally resolve any issues with file transfer between different CAD or CNC applications.
Let me know if the machine shop still have problems opening the STEP file you create.
Also, do you know what CNC application they are using?
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 21-01-2013, 15:21
EricPalmatier's Avatar
EricPalmatier EricPalmatier is offline
FRC #0250 (The Dynamos!)
EricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to behold
Send a message via AIM to EricPalmatier
Hey. Feel free to try the following. It has always worked for me, though your software and/or experience may differ.
Step one: open .ipt in inventor and export as a .dwg.
Step two: open .dwg into autocad
Step three: use the flatshot command to flatten the geometry. Basically gives you a 2d version of your 3d drawing
Step four: save file as a .dfg
Step five: open .dfg into your CAM software and assign tool paths
Step six: print out part on CNC
These steps generally work for me. Let me know if you try it and it works/ doesn't work.! Ill find out what CAM software we use to add to this to hopefully make it as relevant as possible.
Good luck!!
"Engineering is a great profession. There is the satisfaction of watching a figment of the imagination emerge through the aid of science to a plan on paper. Then it moves to realization in stone or metal or energy. Then it brings homes to men or women. Then it elevates the standard of living and adds to the comforts of life. This is the engineer's high privilege."
-Herbert Hoover
Unread 26-01-2013, 18:24
DonRotolo's Avatar
Back to humble
FRC #0832
Another alternative is to select a face of your part, and then export it as DXF. Most CAM programs can handle DXF input.
Your absolute best bet is to ask them what file format they need.
