Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 21-01-2013, 14:20
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
katsauga has a little shameless behaviour in the past
Question Labview Help
When I startup my Labview and choose new project, what template do I choose?
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 21-01-2013, 14:23
Re: Labview Help
Start with Arcade Drive Robot - hardware or simulation
Unread 21-01-2013, 14:48
katsauga's Avatar
Lead Programmer
Re: Labview Help
that isnt an option, here are my options:
Blank Project
Blank VI
Simple Slate Machine
Queued Message Handler
Actor Framework
Finite Measurement
continuous measurement and logging
feedback evaporative cooler
instrument driver project
labview FPGA control on compact rio
Labview FPGA Project
labview waveform and aqquisition and logging
labview realtime control
robotics project
which is it?
Unread 21-01-2013, 14:57
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Labview Help
I've never had something similar to those options before, but if anything it's because I would assume you didn't update your labview and driverstation with the updates located here.
https://decibel.ni.com/content/docs/DOC-26315
CTO/Head Programmer of Team 1710
Unread 21-01-2013, 15:00
Re: Labview Help
That means you haven't installed everything you need for FRC.
The Kit DVD was just the start.
Now you need to apply the Updates on this page: http://www.usfirst.org/roboticsprogr...ical-Resources
LabVIEW Utilities Update (required for all Teams)
LabVIEW Updates (only for Teams programming in LabVIEW)
P.S.
I like the page that Cyrus posted.
Unread 21-01-2013, 15:13
katsauga's Avatar
Lead Programmer
Re: Labview Help
this what my startup looks like, is this normal?
Name:	labview startup.jpg
Unread 21-01-2013, 15:17
Re: Labview Help
That's not the FRC startup window.
Go to Tools -> Choose Environment
then you should get the choice shown in the first attachment below.
Pick LabVIEW for FRC and click the box to Make this my default setting, then Apply.
We normally see the second attachment:
ID:	13605  Click image for larger version
Unread 21-01-2013, 15:19
katsauga's Avatar
Lead Programmer
Re: Labview Help
i click on the shortcut, Labview 2012. it sais launch labview, i click. the page i posted comes up
Unread 21-01-2013, 15:22
Re: Labview Help
Did you install the FRC LabVIEW updates linked in the earlier posts?
Does Tools -> Choose Environment show you any choice other than LabVIEW?
Unread 21-01-2013, 15:27
katsauga's Avatar
Lead Programmer
Re: Labview Help
yes
Unread 21-01-2013, 15:29
katsauga's Avatar
Lead Programmer
Re: Labview Help
wait, its looking normal now, it just didnt register the updates, i installed them like 30 seconds ago
Unread 21-01-2013, 15:31
katsauga's Avatar
Lead Programmer
Re: Labview Help
so which templaate do I choose again?
Unread 21-01-2013, 15:40
Re: Labview Help
Under New use FRC cRIO Robot Project to start with new robot code.
Use FRC Dashboard Project if you want to start modifying the default Dashboard.
