Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 20-01-2013, 09:58
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
pic: Shot in the Basket
Unread 20-01-2013, 10:04
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: pic: Shot in the Basket
Originally Posted by Tubatroopa View Post
shooting into the pyramid was an interesting task.
Agreed. People seem to forget that the pyramid goal is a horizontal target making it much more difficult to shoot into then the vertical goals.
Don't assume that just because you can shoot into the vertical goals means that by changing a few things you can score in the horizontal goal. I bet we will see a lot of discs which are shot at the pyramid goals bounce off the chains and the center spoke. Or even bounce off the bottom of the goal.
I'm not saying its impossible or we will never see it happen, just that it will be very uncommon to see a team shoot into the pyramid goal.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 20-01-2013, 10:08
45 Alumni
AKA: Peyton Yeung
Especially since the closer you are to it the harder it is to hit (due to angles)
461 Westside Boiler Invasion
45 Technokats
Unread 20-01-2013, 10:31
Chris is me's Avatar
AKA: Pinecone
If only there was some way to get right up close and just puke frisbees into there... nah...
Unread 20-01-2013, 10:51
45 Alumni
AKA: Peyton Yeung
Our 2000 robot basically did that with balls. Humans fed it over the wall and it reminds me of someone swallowing something and the regurgitating it into a trough.
45 Technokats
Last edited by Peyton Yeung : 20-01-2013 at 11:21. Reason: forgot about cached pages
Unread 20-01-2013, 10:55
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
http://forum.technokats.org/index.ph...ch=140;im age
The link leads to a sign-in page.
Unread 20-01-2013, 11:22
45 Alumni
AKA: Peyton Yeung
http://www.chiefdelphi.com/media/photos/13086
Fixed hopefully
45 Technokats
Unread 20-01-2013, 13:51
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I know. I really wanted to make a simple dumping mechanism, but I just can't seem to get close enough.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 21-01-2013, 12:51
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Sure there is, climb baby climb.
Unread 21-01-2013, 15:51
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
Can't only colored Frisbees be scored on top of the Pyramid?
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 21-01-2013, 16:24
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
If you score white frisbees into pyramid it doesn't count.
Unread 21-01-2013, 16:29
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
For all intensive intent and purposes, practicing with any colored frisbee doesn't matter.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 21-01-2013, 17:31
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Originally Posted by CalTran View Post
For all intensive purposes, practicing with any colored frisbee doesn't matter.
Did you know that the actual phrase is, "for all intents and purposes." I had no idea until about a year ago, and it blew my mind!!!!!!
http://wiki.answers.com/Q/Is_the_saying_'all_intents_and_purposes'_or_'all_i ntense_purposes'
On a related note, yes, for practice it doesn't really matter which color.
www.sharkattack744.com
