Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 19-01-2003, 08:34
jdawson jdawson is offline
#0910 (Decoma/Foley)
jdawson is an unknown quantity at this point
Post Fuses
One of the fuses went bad on the robot controller (black round ones). Can anyone tell me where I can buy these? Are they available at Rdio Shack?
Thanx in advance for any help
Joel Dawson
Mentor Team #910
Unread 19-01-2003, 08:46
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
make sure it's pushed in all the way. at one competition, we took our robot out for a match, and the fuse error light was on. we were confused, cause it had been fine at the last competition (we went to three last year), and no one had touched it since. a technician came over, spent 5 minutes trying to figure out what was wrong, and came to the conclusion that one of the fuse leads had popped out somehow. 3 seconds later, he bent the lead so it was straight again, popped it back in, and everything was working.
if that doesn't work, i would suggest talking to innovationfirst, as they would know exactly what fuse you need.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 19-01-2003, 09:33
Check in Digikey Catalog Page 961
Unread 19-01-2003, 09:55
Matt Reiland's Avatar
'The' drive behind the drive
A fuse pack for the controllers is available on the Innovation First website also
Unread 20-01-2003, 15:15
Found them
Thaks Matt found them at Innovation First.
Wonder why it blew though?
Unread 20-01-2003, 15:23
Jdawson,
which of the four blew, that may lead you to what part of the controller caused it to blow. It has happened before to us, then it mysteriously went away.
Matt
Unread 20-01-2003, 16:05
F3 aux on the robot controller.
Unread 21-01-2003, 00:30
The Aux fuse is intended to protect external devices powered from the controller. The manual suggests it is for powering the gyro only. If you connected something instead of the gyro then it was either wired wrong or shorted the line intended to feed the gyro.
Unread 21-01-2003, 07:23
Thanks I am sure that is what happened. I did not notice that it said to connect the gyro to that one pin. That won't happen again..............
Unread 21-01-2003, 23:28
To paraphrase a well known axiom...
Those who fail to learn from their mistakes are disposed to relive them.
Unread 22-01-2003, 11:31
Element945 Element945 is offline
#0945 (Element 945)
Element945 is an unknown quantity at this point
WOW WE STILL HAVENT GOT OUR FUSES !!!!!!!
"We haven't failed, we just found 10 thousand ways it doesn't work." T.E.
Element 945
Paragon (A.K.A. The Hulk)
Unread 22-01-2003, 12:45
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
First off, don't shout. All caps is the online equivalent of shouting. Second, Team Update #6 says that FIRST just received the 40A fuses, and four of them are being shipped out now.
Jeff Waegelin
Unread 23-01-2003, 08:02
#0945 (Element 945)
ITS NOT SHOUTING ITS ENTHUSIASM !!!
and since when did we listen to FBI ?
Element 945
Unread 23-01-2003, 13:17
#0945 (Element 945)
BLAH !!!!!!
Element 945
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Blowing Relay Fuses archiver 2000 2 23-06-2002 21:57
Triping Timed Fuses Joe Canavan Electrical 2 21-02-2002 09:34
Internal Fuses (PTC Resistors) on Window Motors bigqueue Technical Discussion 6 08-02-2002 21:34
Those 60Amp fuses... Anton Abaya Electrical 5 18-01-2002 07:41
