Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 21-01-2013, 17:56
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Working With Cable for Elevator
We are looking at using an elevator/telescoping arm for climbing the pyramid this year. Right now the design requires a 2 stage elevator which makes me lean towards using cable and pulleys to drive the arm since we could use a single motor/gearbox to drive both stages. I found some good information in old threads on cable types to use and how it needs to be routed but I didn't find a whole lot on what teams actually used for pulleys and anchors.
So I'll pose the question to teams who've done elevators before, where do you get pulleys from and what do you actually tie your cable to as an anchor? I found some pulleys on McMaster but I'd like to use small diameters (~1") to make it fit better in the mechanism. The few pulleys with bearings around that size were only rated for 175 pounds which doesn't give much of a safety factor if our robot is near full weight. The pulleys without the low friction bearings could support much higher weights but I'm not sure if the bearings would be needed.
Unread 21-01-2013, 19:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Working With Cable for Elevator
Bearings are always a good idea, since friction will be a major factor.
We once made our own aluminum pulleys.
Unread 21-01-2013, 21:04
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
For our FTC robot this year, and with the expanded range of allowed materials, we decided to use the 80/20 liner motion slide bearing options.
Pictured below is our two stage lift using 600 lb test kevlar core, braided polyester covered cord. It is thin yet strong and can handle sharp radius pulleys.
We used shoulder screws with 8mm OD shoulder and 6mm thread to mount our pulleys both in the frame slots and on the slide plates.
We made our aluminum pulleys on the lathe and pressed them onto cheap roller skate bearings of the "mini" size having 8mm IDs by 19mm ODs (Skate bearing types: micro-16mm OD, mini-19mm OD, std. 22mm OD). You can also Locktite the pulleys onto the bearing ODs.
For an even smaller pulley, you can also forgo bearings and just use the shoulder screw as a precision ground axle and have the aluminum pulley spin right on it, with just a little lubrication, but the pulley bore must still be a nice slip fit to work well.
We really liked the infinitely variable positioning that the shoulder screw on slotted framing gave us. You have to use a washer against the slot and the end of the shoulder to have proper grip on the frame, and you can use a larger ID washer fitting on the shoulder OD to handle the spacing & location of the pulley along the shoulder length.
The cord end anchor point was also a shoulder screw without a pulley, and just a small bowline knotted loop captured by the head of the shoulder screw.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 21-01-2013, 21:27
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Pictured below is our two stage lift using 600 lb test kevlar core with braided polyester covered cord. It is thin yet strong and can handle sharp radius pulleys.
We made our aluminum pulleys on the lathe and pressed them onto cheap roller skate bearings of the "mini" size having 8mm IDs by 19mm ODs (Skate bearing types: micro-16mm ID, mini-19mm OD, std. 22mm OD). You can also Locktite the pulleys onto the bearing ODs.
For an even smaller pulleu, you can also forgo bearings and just use the shoulder screw as an precision ground axle and have the aluminum pulley spin right on it, with just a little lubrication, but the pulley bore must still be a nice slip fit to work well.
The cord end anchor pointwas also a shoulder screw without a pulley, and just a small bowline knotted loop captured by the head of the shoulder screw.
-Dick Ledford
We used the same concept for our linear lift in 2011.
https://kusha.me
Unread 21-01-2013, 22:01
StealthMentor StealthMentor is offline
FRC #1802
StealthMentor is an unknown quantity at this point
1802 used pulleys with bearings for our cable powered lift that we re-purposed from replacement sliding patio door rollers (they were cheap and worked very well). Bought them at lowes for something like 3$ a pair.
Unread 21-01-2013, 23:32
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Pulleys - McMaster has some real cheap solid plastic pulleys we used when we were still doing lifts.
Cable - 3/32 steel stranded cable with a nylon jacket. Use crimps and thimbles on the ends you want to hook to. You need to strip the jacket before using crimps. This cable seems to bend very well when needed yet resisit kinking.
Grounding - or making a permanent end. Drill 3 1/8" holes in a row. Thread through the holes and pull tight. We never had one of these fail
Christopher H Husmann, PE
"Who is John Galt?"
