Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
Unread 21-01-2013, 19:20
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
different images in labview
Hello. I am doing vision tracking in labview on the dashboard. One issue I am having is getting a rectangle on the original image. Yes it draws the rectangle on the image but it does so on the thresholded image. Is it possible to draw it on the original image while using the threshed image for the actual processing?
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 21-01-2013, 19:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: different images in labview
Since you're talking about the LabView dashboard, that should go over in the LabView or General programming forums, not Java.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 21-01-2013, 19:45
I agree that the question is more likely to be answered on the LV forum, but since I'm here, it is easy.
In the lower right is a bit of code guarded by the Annotate button. The image going into it is the result of the threshold. Delete that wire and connect up the wire going into Original. If you only want one image display, you can delete the processed one and move the Original Image terminal to receive the output of the Annotate.
And now, back to regularly scheduled Java programming.
Greg McKaskle
Unread 21-01-2013, 22:03
Hypnotoad's Avatar
Woops! Sorry about that. Almost everything we do is java now so I forget sometimes that the dashboard side of things is currently labview. Thanks for the tip. I'll try it out as soon as I get back to the lab.
My teeth are false.
