Go to Post GP is a measurement that can only apply to yourself. To apply it to another is unfair to that person/group. - Andrew Schreiber [more]
Unread 21-01-2013, 20:40
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
3 Fried Side Cars
My Electrical/Programming team had been making good progress until today when we fried 3 digital side cars. We had a functioning drive system on our test frame and successfully tested relays that would be used for our pneumatics and vacuum pick-up system.
After assembling the pneumatics hardware - compressor/relay/pressure switch and solenoid and setting up our Java code, we turned on power while but got only a brief burp out of the compressor and then smelled smoke from the side car.
We quickly killing power and carefully checked the code, wiring and hardware - everything checked out OK. We removed everything that had been added since our last successful operation (pneumatics and vacuum pump), replaced the side car, and turned power back on - only to get another smoking side car.
This time we removed everything on the side car except the power supply and the ribbon cable, double checked everything again including voltage going to the side car, and proceeded to fry a third side car. A post mortem revealed one obviously roasted IC chip inside.
We were utterly perplexed, until one student noticed that the ribbon cable going from the CRIO to side car was not neatly trimmed and the excess at the end was butted up again the solenoid breakout board on the next CRIO slot - right against a row of protruding and quite pointy solder beads!
We fixed our ribbon cable, but haven't yet risked a fourth side car. Does anyone have any insight as to whether its is feasible for an unprotected end of a ribbon cable to short against a breakout board and cause a smoking side car? Also, is it possible we could have damaged the breakout board or modules?
Unread 21-01-2013, 20:42
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: 3 Fried Side Cars
Make sure the power connector isn't plugged in backwards for the sidecar.
Those WAGO connections can easily be switched around if you aren't careful.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 21-01-2013, 21:12
FRC #1493
We'll double check it. It could be the cause of the second and third failure, but I'm sure the Wago was not touched between successful operation and the first failure.
Unread 21-01-2013, 21:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The sidecar has reverse voltage protection, so you should be OK if you "accidentally" hook it up backwards.
We blew a sidecar once because we had an excess PWM cable hang down and touch the negative post of our PDB, causing a short. Anything is possible, though I don't see how a short in the ribbon cable would blow something in the sidecar. Everything in the sidecar is "downstream" of the ribbon cable, and shorting the solenoid breakout to one of the 4 grounds in the ribbon cable would be more likely to blow the solenoid breakout than the sidecar.
Here are the control system schematics to help diagnose what's happening: http://www.usfirst.org/roboticsprogr...stem-resources
Unread 21-01-2013, 21:41
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Sounds like you may be having the same issues we had. If nothing else is found, you may just have an intermittent short somewhere.
Academic Student (Forever)
Unread 21-01-2013, 22:07
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
This happened to us in 2011 at Boilermaker. We went through 3 digital sidecars and only 1 showed real signs of burn. We checked everything and we didn't notice anything wrong. Our 4th side car that year works and continues to work. Our only possible cause was the possibility of a case short in a bb 775 motor.
461 Westside Boiler Invasion
45 Technokats
Unread 21-01-2013, 22:08
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Dead link for me.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-01-2013, 22:21
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Link
Unread 21-01-2013, 22:24
CalTran's Avatar
MST Rolla Senior
Originally Posted by DominickC View Post
Fixed it in my post as well.
Unread 21-01-2013, 22:35
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If you're using the solenoid breakout and have 12V wired to it, I'm liking your theory of the excess ribbon cable touching a 12V circuit on the solenoid breakout. There's plenty of chips on the sidecar that aren't expecting 12V and aren't likely to survive it showing up on an unexpected pin. Even moreso if you're powering the solenoid board with 24V.
The solenoid breakout and module is likely fine, since it's rated up for the voltage it's carrying. If I'm reading the spec sheet for the 9403 module correctly, it can withstand +-30V on the inputs with no ill effects, so it's probably fine as well. Wouldn't hurt to test all the channels you'll be using, however.
Unread 21-01-2013, 23:04
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
This is a long shot, but make sure your power system is healthy from the battery wire issue (improper polarity Anderson Power Plug).
Have you drilled or machined near the DSC? The old ones are not conformally coated, and can short out if you get a little spec of metal in there.
When you mentioned "fixing" the cable, were you referring to moving it away from the protruding solder points or taping up damaged areas? If anything, try a new one on your next test. If it works, throw the old one out.
You might want to break out the multimeter and check everything for continuity. Are your fuses all correct? Have you made any wiring mistakes? Double check everything in accordance to the FIRST manual.
Do you have any BaneBot motors? If you had a BaneBot that was case shorted, for instance, you could have many mysterious electrical problems. If you do have a BaneBot, make sure you machine any OTS transmission to allow for air passages (most, if not all BaneBot issues are overheating related).
Unread 22-01-2013, 01:59
If you could post a picture of the burned IC we may be better able to determine what happened. Alternately, please tell us which one(s) are damaged.
Unread 22-01-2013, 08:20
Following your description of the ribbon cable, I agree with Kevin. It sound like 12 volts or 24 volts if you are wired for 24 volt solenoids backed up the exposed ribbon and took out the side car. Since there are both inputs and outputs on the ribbon cable, there is likely some serious damage to the sidecar. Pictures are worth a thousand words.
Unread 22-01-2013, 12:04
FRC #1493
Problem sovled. Thank you to everyone who provided input. The issue was definitely ribbon contact with the solenoid board. Opening up the three side cars revlealed the same chip (U2) was burned. We did some testing and found that only a very light pressure was needed to make electrical contact with the cut end of a ribbon cable, which would send 24 volts into the side car. We tried the ribbon flush and taped the end with electrical tape, and everything works fine with a new side car. Luckily nothing else appears damaged.
So, the lesson learned is secure all possible points of electric contact.
Unread 22-01-2013, 12:50
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Now that the problem has been solved.
3 Fried Sidecars....
...and a COKE.
If it were 4 Fried Sidecars, this would have made more sense.
