Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
Go Back   Chief Delphi > Technical > CAD
Unread 20-01-2013, 09:35
steelcity steelcity is offline
steelcity is an unknown quantity at this point
using downloaded KOP in frame generator
Hi I'm new to inventor and I'm having a hard time figuring out how to use the andymark c-channel given for the base as a part option in frame generator.
I would really appreciate some help.
Thank you
Unread 21-01-2013, 14:51
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: using downloaded KOP in frame generator
Frame generator is used to create a frame from a sketch. The KOP frame parts are already modeled and would not be recognized in Frame Generator.
Let me know what modifications you are trying to make to the frame parts and I can assist you with the work flow.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 22-01-2013, 00:59
I am trying to alter the C-channel included in the Andymark base Kit to different sizes, sizes not previously modeled, yet i cannot seem to find a way to do so.
Is there a way to edit the dimensions of the modeled drive train or of any modeled part such as the C-Channel?
Unread 22-01-2013, 01:22
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
what I do is place the c-channel in an assembly make a plane extrude it and set it to cut, it should be under something like preparation.
Unread 22-01-2013, 14:27
Let me know what dimension you would like and I will create a short video to show you how to modify a STEP file. For example, do you want a 20" length of c-channel?
The advice in the previous comment is good.
Phil Dollan
Autodesk Inc.
Unread 22-01-2013, 22:01
i Need a 23'' piece as well as a 28 inch piece. As for the advice posted above, i don't completely understand, am i to place the plane on piece and then somehow extrude it?
Unread 23-01-2013, 14:25
AKA: Mark Omo
FRC #1703 (RATS)
Precisely and simply set the extrude to cut
Unread 23-01-2013, 15:51
I will post a 23 and 28 inch part later today.
Phil Dollan
Autodesk Inc.
Unread 24-01-2013, 00:35
Zip file attached contains 2 channels. One is 28" and the other is 23". They are STEP files. Double check the hole locations work, if not, I am posting a video to show you how to modify the length of a channel in STEP format.
Phil Dollan
Autodesk Inc.
Unread 24-01-2013, 00:38
Video of how to modify a channel in STEP format.
Phil Dollan
Autodesk Inc.
