Go to Post For We Will Rock You, we quit counting Saturday morning when it got to 12 times. - Gary Dillard [more]
Unread 22-01-2013, 13:52
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
Re: 30pt climb under 15 seconds
Originally Posted by Keyreaper View Post
Faster than 15 seconds? I can't wait to see this elegant solution in action. Everything my team has brainstormed up we believe will take must more time than that...
It's reasonably elegant but it's not earth shattering by any means. We are using pneumatic cylinders combined with springs and the extension/contraction time of the cylinders is a bit under 1 second each at full weight. We need to articulate a few times to travel up the full pyramid and that's that. As the compressor is slow, so we will be storing a ton of air on the robot initially to power the cylinders the entire way. It comes out to something like 6 seconds or so if you just let the cylinders go full speed. Our concern is that at each step the robot will "bounce" and at that speed, it could bounce off. So we will likely slow it down with flow restriction to make sure nothing moves too quickly.
-Mike
