Go to Post You pick the best person for the job whether they are black, white, asian, hispanic, female, or male; NOT so you 'look good' when they publish your team picture in the school paper, but because they can get the job done right, on time, with a passion. - Pavan Dave [more]
Unread 22-01-2013, 14:10
Danny Blau's Avatar
Danny Blau Danny Blau is offline
50% of life spent in FIRST!
no team (AndyMark)
Danny Blau is a jewel in the roughDanny Blau is a jewel in the roughDanny Blau is a jewel in the rough
pic: FRC 3184's drop test results 2
Unread 22-01-2013, 14:11
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: pic: FRC 3184's drop test results 2
How was the frame put together?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 22-01-2013, 14:23
Danny Blau's Avatar
no team (AndyMark)
It used the Press Fit Framing system from McMaster
Tubes are P/N 47045T48
Connectors are P/N 47045T81 - 47045T86
Unread 22-01-2013, 18:34
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Another reason our team didn't choose to climb to 30. The sacrifice of the frame was worth it to prove the damage.
Go Orange Alliance!
Unread 22-01-2013, 21:58
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I would be interested to see results with a bolted/rivited/welded/sheetmetal frame. As most teams won't be using the system you mentioned, these tests are of limited utility to the community.
Like everyone else said, don't fall.
-Plutarch
Unread 23-01-2013, 09:35
weighted in down to 155lbs. Lifted it to 7.5ft off the ground...
what did it do to the floor?
Unread 23-01-2013, 10:54
Danny Blau's Avatar
no team (AndyMark)
Our big thick concrete floor survived with little more than a scuff where the robot impacted.
AndyMark Inc
Design Engineer, FTC Project lead
Unread 23-01-2013, 12:04
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We use a similar connector from a different vendor, I wonder what it would have looked like had the connectors been pinned to the extrusion instead of just pressed in.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 23-01-2013, 19:23
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Some of the connectors appear to have sheared in the other picture, so it doesn't seem like press fitting vs screw/pin fitting would make a difference.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
