Go to Post This isn't about practical, it's about having fun and thinking outside the box... tetrahedron.... whatever....:rolleyes: - Cyberguy34000 [more]
Unread 22-01-2013, 16:28
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Gyro Recommendation or Arduino
We are wanting to implement the gyro for control, but for what we are wanting to do with it, the included gyro is too slow (250 degrees/second max). Is there another gyro that anyone could recommend, or should we go with an arduino controlled gyro. I've seen them for ~$12, and they will handle up to 2000 degrees/second. But then we would have the added complication of sending that data back to the cRio as a sensor input. I haven't seen any guides for arduino input control.
Thanks.
Unread 22-01-2013, 16:52
Re: Gyro Recommendation or Arduino
What are trying to control with a gyro that 250 degrees per second is too slow?
Unread 22-01-2013, 16:54
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Depending on what you're trying to do, you could mount the gyro's axis at an angle of 82.8 arcdegrees from being aligned with the rotation axis. The gyro would then be desensitized by cos(82.8) = 1/8 (ie 2000 deg/sec about your primary axis would be sensed as 250 deg/sec about the gyro's axis).
Russ
Unread 22-01-2013, 17:47
AKA: Chris Rollison
Russ
This is excellent information and I'm honestly going to enjoy trying to understand it. The greatest part of this program is the advanced material that I get to try and figure out.
