Go to Post Patience, grasshopper. They'll get to it. - Rick TYler [more]
Unread 22-01-2013, 20:24
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Weird networktables error?
Originally Posted by clandry94 View Post
It seems it is an error with Roborealm not sending a double. Does anyone know how to get roborealm to send values as doubles?
I just spent the last two hours working on roborealm and im incredibilly frustrated.
My main problem is that the variable [BOUNDING_COORDINATES] does not update! Im able to send a string that has the different values of the bounding rects but when i move the robot the variable doesnt update it unless i change it to a different variable than change it back to [BOUNDING_COORDINATES]
also, it seems that your unable to change the values of the keys. You have to get a new key but define it as a double before you use it
