Go to Post this is a TEAM effort...teach them something. Who knows, with a little luck, you might just learn something yourself! - Nuttyman54 [more]
Unread 22-01-2013, 16:32
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Best motor/gearbox for lifting
What is the best motors and gearbox to use for lifting this year?
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 22-01-2013, 16:36
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Best motor/gearbox for lifting
Whichever one works in your prototype. This isn't a kind of thing other teams can answer for you.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 22-01-2013, 16:48
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Any motor can lift any load-- it's just a matter of time.
If you want to hang quickly then you need larger/more motors trying to lift the robot.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 22-01-2013, 16:59
Figure out how fast you want to lift your robot (how many seconds to lift)
Figure out how high you want to lift your robot (the change in height of the center of mass, in meters)
Figure out how heavy your robot is (in Newtons).
Then you can calculate the power (in watts) required to lift your robot the desired height in the desired time:
watts = Newtons*meters/seconds
Once you know the required watts, you know you'll need a motor with at least that much power. To be sure, multiply by a safety factor.
Then, gear that motor so that when it is spinning at half free speed (max power), it will lift the motor the desired distance.
Unread 22-01-2013, 20:00
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I know our team has designated 2 CIMs for hanging, but it is a high priority for our team, it really depends on how reliable you want it to be and how important it is that you hang.
Unread 22-01-2013, 20:02
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
my team is going with a bag motor and a versa 1:100 gearbox for lifting
Unread 22-01-2013, 20:27
Billfred's Avatar
Billfred Billfred is offline
...or, less robot.
Maybe this'll be the first time in our history we don't bother ballasting up our robot...we've done everything from steel I-beams to dumbbells last year (wrapped in black tape to keep with the theme).
Another concern you should have: Will the design hold position after the power is cut at the buzzer? Some designs will regardless of motor, others won't.
Unread 22-01-2013, 20:36
Have you done the math to make sure you won't exceed the torque rating on the output shaft of that 100:1 gearbox?
Unread 22-01-2013, 21:07
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Then, divide the wattage by 12v and make sure you're not going over the current limits of the breakers. If you are, you are trying to go too fast (or you're too heavy)
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 22-01-2013, 21:21
AKA: Mark Omo
FRC #1703 (RATS)
eek I have not where is this data?
edit: found it and it is thanks though for the thought I had visions of expensive motor/gearbox combos breaking
Unread 22-01-2013, 22:06
Close, but no cigar.
The motor wattage rating is the mechanical power at the output shaft, not the electrical power the motor is consuming.
But your point is well taken. The operating current should be checked.
You can find the operating current by using the motor curves or this motor calculator.
Unread 22-01-2013, 22:16
Sparks333's Avatar
Robotics Engineer
AKA: Dane B.
Fair point - but running at peak efficiency those motors are around 80% efficient anyway, so you can definitely get a ballpark assuming mechanical energy is equivalent to electrical energy. The actual motor model is a lot less fun
Sparks
Unread 22-01-2013, 22:35
pfreivald's Avatar
AKA: Patrick Freivald
We tested our lift today, and are certain that one CIM *can* do the job... But we are using two, even though the lift isn't appreciably faster, just to be sure. (We have the weight, so the extra CIM is just insurance of the current/power variety.)
"Just To Be Sure!" could be the motto for our climbing team... We're likely over-engineering everything, and adding in robot-safety features that really aren't necessary, and we're glad to do it!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 22-01-2013, 22:37
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Fun is a matter of perspective. I happen to think actual motor models are incredibly fun.
And motors running at maximum power are definitely NOT running at their peak efficiency. Current draw will be higher than you think.
Ether is right, you need to do the math. The calculators he pointed to will help you with that.
Richard Wallace
since 2003
Unread 22-01-2013, 22:39
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Adding ballast and needing extra weight is a foreign concept to us.....
