Go to Post When we learn physics, we almost always "ignore friction". The real world never does... - Mike Betts [more]
Unread 22-01-2013, 21:57
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Re: Team 3081 - RoboEagles Prototype Launcher
Has anyone tried using a shooter with bane bots rather than CIMs?
Unread 23-01-2013, 22:44
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We have not tested with bane bot motors. I could give some speculation to how they would work if asked but it wouldn't take my speculation for much.
*Launcher Update*
We did some additional testing this week and found that in order to get more distance, height and accuracy with this specific launcher it is required to have the extra mass on top. The mass allows for additional momentum from the wheel (think f=ma) and causes less motion loss when launching the frisbee due to compression. The frisbees we launched without the saw blade on top traveled aprox. 3/4 the distance of the frisbees with the saw blade attached.
Safety Warning I highly recommend anyone attempting this grind the blades off of the saw, add warning signs and tape the edge of the blade with safety tape. We made a very large cut in one of our tables.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 23-01-2013, 23:20
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Our team tried direct driving a Banebot with the 6" KOP wheel. At an incline between 20-30 degrees we got about 15 ft of distance.
Unread 24-01-2013, 14:32
FRC #3200
My team has already found use for all 6 CIMs so we were going to prototype our shooters using the bane bot motors. Has anyone tried prototyping a linear two wheeled shooter with it and what were the results?
Unread 24-01-2013, 14:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
There are a large number of banebot motors. Could you be more specific on which banebot motor you direct drove?
Unread 25-01-2013, 21:44
FRC #0611
My apologies. We were using an RS-775.
