Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 22-01-2013, 17:48
cx41546 cx41546 is offline
FRC #4776
cx41546 is an unknown quantity at this point
Unhappy PROBLEMS WITH SETTING UP "NEW REMOTE REGISTRY"
I am having a problem setting up the connection. i cant find the kernal file i need. somebody help me please
Unread 22-01-2013, 23:35
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: PROBLEMS WITH SETTING UP "NEW REMOTE REGISTRY"
The Kernel Image file should be found in the WPILib folder in your WindRiver installation directory ("C:\WindRiver\WPILib" by default). Make sure you use the right file for your cRIO version; "cRIOFRC_vxWorks" for an 8-slot cRIO or "cRIOFRCII_vxWorks" for the newer 4-slot version.
If the WPILib directory is not there, make sure you have installed the C++ update for 2013 found here: http://firstforge.wpi.edu/sf/frs/do/...tware_up date .
There is an excellent set of instructions for the whole process found over on the control system documentation site: http://wpilib.screenstepslive.com/s/...iver-workbench .
Unread 27-01-2013, 10:28
FRC #4776
Smile Re: PROBLEMS WITH SETTING UP "NEW REMOTE REGISTRY"
thank you very much! i will be sure to remember your team name when the competitions roll around!
