Go to Post i swear, if it were april fools day, i would not believe this whole lord dumpling/dean kamen thing...but then again, this is FIRST - sure_smile [more]
Unread 23-01-2013, 11:33
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Is my Solenoid wired correctly?
I have a double solenoid festo valve, I'm pretty sure code the fine however I'm not too sure on the wiring. We have 24v going into the wago, and both double pin connectors from the festo going into slot 1 and 2 (+) and sig. Nothing seems to be lighting up. The festo does work manually.
Unread 23-01-2013, 11:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Is my Solenoid wired correctly?
that looks like the analog bumper, not the pneumatics bumper....????
Unread 23-01-2013, 11:38
You have it in the wrong module and Breakout.
That's an analog module.
P.S. Great descriptive picture you took, by the way!
You have the solenoid module in slot 1. It goes in slot 3 and the analog module goes in slot 1.
Here's what the correct one looks like. Note the green LEDs on the module and the shorter Breakout with 2-pin connectors rather than 3-pin connectors.
Make sure you move the 24v wago to the solenoid Breakout. The Analog Breakout should only get 12v.
Unread 23-01-2013, 12:31
FRC #4665
Thanks for the help!
Unread 25-01-2013, 18:03
FRC #4665
Here I what we are currently at and still nothing... The wago is getting 24v. Nothing is lighting up. Could this be the code or will something light up regardless of the code being deployed?
Unread 25-01-2013, 18:18
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Silly! You got to plug it into the cRIO!
But in all seriousness, if it has 24V on it, then it should be working (electrically). Do the LEDs on the NI 9472 module light up when you trigger a solenoid?
If so, then the problem is electrical.
If not, the problem is at least programming.
Those LEDs will light up regardless of what is plugged into the top of it.
It should be in slot 3, or the 3rd slot from the ethernet and power connections for the cRIO.
I hope this helps.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 25-01-2013, 18:34
FRC #4665
The NI 9472 should be in the third slot down from the Ethernet plug in?
Unread 25-01-2013, 18:41
RyanN's Avatar
RyanN
Yes.
To check everything, you can use the cRIO imaging tool to verify the correct module configuration. They will all be GREEN to indicate that everything is plugged in properly. You'll see RED on modules that are in the incorrect order.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 25-01-2013, 18:47
FRC #4665
Thanks a bunch!
