Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-01-2013, 11:50
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Bearings Falling off
Hey, is anyone else having this probel, the bearings given to us in our kit of parts, they keep sliping off the wheels when we put any sort of spining force on them.
We altered 2 oour wheels, and that would explain it, except that the ones we did not alter also slip off so we cant spin our wheels at all.
Any help would be useful. Thx!
Unread 23-01-2013, 11:56
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Bearings Falling off
When assembling the wheels to the axles, did you include the spacer sleves?
Unread 23-01-2013, 11:59
Did you make sure to use an arbor press or a wooden block + mallet to hammer the bearings in properly?
Along with the spacers, you really shouldn't encounter this problem. We have never had it happen, as far as I can remember.
If you do have an issue, please contact AndyMark and they can be of assistance to you, although if your alteration to the wheel is causing the problem, I would not expect a replacement. You never know though!
Unread 23-01-2013, 14:10
FRC #4633
OK, thank you for the help, we ended up just making our own spacer, and we are pretty sure that the change to the wheel made it better, because those wheels have the bearings that fall off the least. anyway, after just spending 3 hours trying to make the correct size spacers, we have it all setup.
Also, the sleeves that they gave us were pretty soft, and when we tried to cut them, they crumpled like tinfoil, we just made some out of copper pipe.
Thanks for the help, and good luck
Unread 29-01-2013, 20:46
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
A few of the wheels we got the bearings dropped right into place, no press or deadblow and block needed, same with the plastic pulley halves. With spacers in place its not a big deal. just had to make sure none of them slipped out while putting them on the chassis and then have to undo the bolt and the spacers and start again.
Unread 29-01-2013, 21:13
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Back when I was younger (2008) I remember having a similar issue with AL Hex stock (lathed into live axles) being slightly undersized and as a result slipping right through the AM performance wheels/hubs... Some PVC spacers did the trick.
For extra resilience, Some AL round stock can be drilled out and cut with a lathe to make some really nice spacers.
Unread 30-01-2013, 00:09
Physicguy's Avatar
Physicguy Physicguy is offline
It exploded on its own I swear...
AKA: Jeffin James
FRC #2582 (Pantherbots)
Physicguy is just really nicePhysicguy is just really nicePhysicguy is just really nicePhysicguy is just really nice
If you put a bolt in the spacer and clamp it to a vice and use a hacksaw it works just fine...and yes they are pretty soft but they work really well.
