Go to Post I jumped up and yelled when I saw both my teams in the same division. Less running for me in the pits. Thank you, Great Homie in the Sky! - Barry Bonzack [more]
Unread 23-01-2013, 13:10
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: How to display image (RGB, Binary, HSV, etc.) on driver station screen
Originally Posted by 13liud View Post
We are trying to implement vision, but we can't move forward until we can actually see the images we're working with. Is there some way to, once we have an image (RGB, Binary, HSV, etc.) stored as a C++ variable, to display it or see it, preferably as a live feed? How exactly could I do this?
If that's not possible, I need any means of viewing an image file created on the cRIO for testing purposes.
As long as your camera is on the standard IP address, you should be able to see the live feed of the camera on your dashboard.
Unread 26-01-2013, 20:09
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
If you look at the image processing example... there is the following lines:
BinaryImage *thresholdImage=image->ThresholdHSV(threshold); // get just the green target pixels
//thresholdImage->Write("/threshold.png");
BinaryImage *convexHullImage=thresholdImage->ConvexHull(false); // fill in partial and full rectangles
//convexHullImage->Write("/ConvexHull.png");
BinaryImage *filteredImage=convexHullImage->ParticleFilter(criteria, 1); //Remove small particles
//filteredImage->Write("Filtered.png");
Uncomment the commented out lines and the files will be saved to the cRIO. Just then get them off with FTPing to the cRIO (At 10.xx.yy.2) with a program like FileZilla.
The documentation reccommends you comment out the loop before writing to the cRIO flash though to keep it from deteriorating. How important this is, Im not sure of. I did it though, and it worked just fine for our purposes, if not better (Cause we could just enable and grab processed pictures, then reenable again and such.)
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 27-01-2013, 08:52
The cRIO is sold industrially for machine monitoring. The filesystem does wear-leveling and the flash is capable of many many rewrites. It is fine to use the flash for debugging, that is one of the reasons it is there.
Greg McKaskle
