Re: Gearhead mortor not in Kit?
The motor listed in the KOP is the part number for the motor, not the part number for the gearbox assembly, so the short answer is, Yes you can use it. It took our team a long time to figure this one out also. There is some discrepancy though with using PG-71 gear assemblies from previous years because some of them are listed as having a different motor number than the one on the list. The way to fix that is to buy replacement motors for the gear head assembly.
Hope this helps more than it hurts. Edoga |
Sorry for the brain hurting, i meant that we had a couple of motors that weren't in the list. Also, are we allowed to get motors that did not come in the kit of parts list, this is what i originally meant.
Sucks to be ESL... XD |
So if you look at Rule R32, It has a list of available motors for this year's robot. In the list is the motor am-2161 and am-2194. These are the motors used in the AM PG71 and AMPG188. Our understanding is that FIRST lists the part number for the motor, not the gearbox assembly. Your team can use any motor from the list in rule R32 in quantaties from the list in rule R32, you just have to include that in your Bill of Materials. Have fun shopping for motors!
Hope this settles things for you. Edoga R32 The only motors and actuators permitted on 2013 FRC ROBOTS include the following: Table 4-1: Legal Motors Motor Name Part Numbers Available Max Qty Allowed CIM FR801-001 M4-R0062-12 AM802-001A 217-2000 PM25R-44F-1005 PM25R-45F-1004 PM25R-45F-1003 PMR25R-45F-1003 PMR25R-44F-1005 6 BaneBots M7-RS775-12 M7-RS775-18 M5-RS550-12 M5-RS550-12-B M5-RS545-12 M5-RS540-12 M3-RS395-12 M3-RS390-12 4 AndyMark 9015 am-0912 4 Denso Throttle Control AE235100-0160 4 VEX BAG and/or mini-CIM 217-3351 217-3371 4 AndyMark PG am-2161 am-2194 3 Window Motors 262100-3030 262100-3040 Various from FIRSTŪ Choice 2 VEX 2-wire Motor 393 276-2177 2 Snow Blower Motor am-2235 1 Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC) Unlimited Drive motors or fans that are part of a motor controller or COTS computing device Unlimited Fans included in the 2013 Kickoff Kit, FIRSTŪ Choice, or as a Talon motor controller accessory Unlimited COTS servos with a maximum power rating of 4W each at 6VDC Per the Servo Industry, Servo Max Power Rating = (Stall Torque) X (No Load Speed) Unlimited |
Thank you for your, this will definitly settle things, good luck and have fun.
Jesus,
As a rookie team, you are provided with parts in your KOP that are not provided to veteran teams. You can find this list on the KOP section of the First website. Many people are not aware that two KOP versions exist. Veterans are expected to use parts they have received in the past. You should have received two batteries I believe while veterans only receive one. |
Yes, its just I could not find it in any of the two lists. But i think eedoga had it right in saing that it did not include the gear assembly as part of the motor, and so it had a different id #, im pretty sure we found it in our list now, so thank you for your help.
Hopefully we can stop with the problems and get to work on the robot now ![]() Good luck ![]() |
