Track balls are red, Or they are blue - I get deflated, When I'm without you.
  #31   Spotlight this post!
Unread 23-01-2013, 14:57
Re: General LabVIEW questions from a VERY new user
The dashboard shows a few values from the robot by default. It shows two joysticks with 12 buttons and 3 axes. Below are four graphs with the four motor outputs.
If you want to display more, make a dashboard project from the template, add the indicator to the Operation tab, name it the same as the SmartDashboard variable.
Then on the robot, in appropriate location, write the value to the SmartDashboard variable of the same name.
Greg McKaskle
