Go to Post I think it would be beneficial for us frogs to be in the new hopper division - zsm150 [more]
Unread 23-01-2013, 15:18
gamegeek1995 gamegeek1995 is offline
FRC #4701
gamegeek1995 is an unknown quantity at this point
Issue getting code onto the robot.
We are a rookie team, and out group has been attempting to get both Java and LabView code onto the robot. We've done many suggestions found on the forums and followed the step-by-step instruction guide for both.
For each of these, we used the correct imaging for each code and set it up for our team IP (I.E., 10.47.01.02 for the robot, 10.47.01.05 for our netbook).
{while trying Java}
I've taken down every single firewall I can find, opened every port, and wrote a new "rule" for outgoing data as found in a forum post. This did not work. I uninstalled and reinstalled Netbeans modules, as recommended in the forums. We performed updates and re-updates. With our Driver Station, we have greenlights for Communication and Joysticks. When we tried to run the Java, as outline in the FRC step-by-step instruction guide, we had an error code which, at the top, essentially said there was a communication problem.
{while trying LabView}
Deployed every way it said to in the instructions, all the other settings are the same, and no dice.
Does anyone else have this issue or know of a way to fix it? I've spent 4 hours and my friend has spent 8 trying to get this thing to get onto the robot.
