Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 23-01-2013, 14:56
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Measuring Amperage
we may want to measure amperage for our shooter. I'm looking at using a Polulu Hall Effect current sensor (http://www.pololu.com/catalog/product/2199), and am reading the rules:
R49
Branch circuits may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical pathway is via appropriately gauged/rated elements.
R54
Custom circuits shall not directly alter the power pathways between the ROBOT battery, PD Board, motor controllers, relays, motors, or other elements of the ROBOT control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential.
Would putting one of these in the controller to motor pathway (not a CIM motor, a 30A branch circuit) be "inconsequential"? Everyone on our team that's looked at this so far thinks we're legal, but getting another set of eyes on it seems prudent.
Unread 23-01-2013, 14:58
Re: Measuring Amperage
In my mind, 1.1 mOhm is low impedance.
Unread 23-01-2013, 15:04
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
That would seem to be exactly what R54 had in mind when it says "Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable".
The key here is that your additional circuitry isn't doing and direct control of the motor - without it present, the motor would act exactly the same.
2016: Lake Superior WFFA
Unread 23-01-2013, 15:18
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Be sure to purchase some extras and expect to let out some smoke. We used a similar device a few years ago. It worked great as long as the motor didn't stall.
You might want to search on here for "stang sense". You can use a 12" piece of # 10 Ga wire and make a 0.001 ohm resistor. With a voltmeter that will read milli volts it makes a great ammeter. A simple op amp circuit gets you a signal to read with the cRIO.
-Hugh
Unread 23-01-2013, 15:19
What motor controller and motor combination, and at what motor speed and current are you trying to measure?
Answers to those questions could affect the method required to get a useful current reading.
FWIW, using Jag with CAN you just ask the Jag to tell you what current the motor is getting.
Unread 23-01-2013, 15:22
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
We've been using a CAN Jaguar with BDC-Com for all of our shooter testing this year. It's great because it tells us current draw and an exact voltage.
Unread 23-01-2013, 15:23
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yep. Drive your Jaguars off of CAN and you can get the current amperage draw of the motors. Helped us alot last year.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 23-01-2013, 15:40
Doug,
The answer depends on how you implement the introduction of this device on your robot. You are more likely to get accurate readings if you monitor the input current to the speed controller. While it does exhibit some of the PWM current spikes, it has less of the spikes, overshoots and noise that appear at the output of a controller or motor wiring. Without getting into the detail of how to use this device, it would be more appropriate to insert it in the common lead of the speed controller input wiring, if possible. The controller input wiring does not change polarity (although it appears that this device may be designed to look at varying polarity signals). That puts the board at a lower potential and if insulation should fail, less likely to cause control issues in other circuitry. The circuit itself will be inspected as a custom circuit under the rules quoted above for each event you attend. It will also be required to be correctly insulated and isolated from the frame while meeting all other robot rules.
Unread 25-01-2013, 15:57
jmiller18 jmiller18 is offline
FRC #2429
jmiller18 is an unknown quantity at this point
You could always use a current clamp, you just clip it around the wire and it will measure the current without actually having to be part of the circuit between the motor and jag
http://en.wikipedia.org/wiki/Current_clamp
Also, amps are a unit that measures current not amperage.
Unread 25-01-2013, 16:00
Mentor, LRI, MN RPC
http://www.thefreedictionary.com/amperage
amperage: The strength of an electric current expressed in amperes
Current and amperage are generally treated as synonymous.
Unread 25-01-2013, 16:39
FRC #2429
http://physics.nist.gov/Pubs/SP330/sp330.pdf
bottom of page 19
this is the United States's National Institute of Technology (NIST) reproduction of the International System of Units (SI) standards. It clearly says that amps measure current. Amperage isn't technically a word. It is like guesstimate, it is only defined in the dictionary because it is used so often.
Unread 25-01-2013, 18:17
bottom of page 19
Amperage is most commonly measured in amps. What you have said is essentially "Length isn't a real word, meters is".
Unread 25-01-2013, 19:12
Actually, what he is saying is "Meterage isn't a real word, length is".
Unread 26-01-2013, 10:49
While I will understand what you are saying, I am likely to correct you when you use "amperage" instead of "current". For me it is like putting ketchup on cake. It is possible but it makes me cringe.
Unread 26-01-2013, 12:10
Few posts make me actually "laugh out loud" but this sure did.
Thanks for brightening my day
