Go to Post Robot? What robot?! - LightWaves1636 [more]
Unread 23-01-2013, 15:44
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Using Network Tables
Originally Posted by RoboRealm View Post
If you have trouble sending arrays you can always use the Set_Variable module and set something like
/SmartDashboard/coord1x
to
BFR_COORDINATES:0
i.e. 0 is the first value of the BFR_COORDINATES. Likewise BFR_COORDINATES:1 would be the second (coord1y) and so on. Assuming you only want to send the first 4 coordinates this is a possible way to itemize each of the array values and send them individually.
STeven.
do you actually work with roborealm or is that just your name? :
E/ this isn't working, the very top value keeps being set to the very bottom value (in network tables)
So if I set sdfd = 1233, suffer = 3455, it will only update sdfd to 3455
Unread 23-01-2013, 20:04
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Restarting the c/rio over and over again worked.
Almost there, my problem now is that COORDINATES:6 is EVIL! whenever i try to send to COORDINATES:6, it sends it to either COORDINATES:4 or COORDINATES:5. restarting my computer, crio, my .robo file, etc. dont work
