Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 23-01-2013, 16:29
sandbag747 sandbag747 is offline
FTC #3603 (Reed City Cyber Coyotes)
sandbag747 is an unknown quantity at this point
Programming in Pneumatics
I have no clue where to start, no clue how anything works, and I need some help. I need to program a pneumatic piston and I need to know what I need connected, how I do it, anything you guys can say to help. Thanks in advance
Unread 23-01-2013, 16:42
Re: Programming in Pneumatics
See if this helps: Pneumatics Step-By-Step
LabVIEW has example programs that can be run to test that you have your wiring setup correctly.
Look on the Getting Started window under Support -> Find FRC Examples...
Then under the FRC folder there is a pneumatics folder of example programs.
Unread 23-01-2013, 16:49
I don't have time to go through it all now but that looks like exactly what I need, thanks
