Re: Gearhead mortor not in Kit?
Thank you for your, this will definitly settle things, good luck and have fun.
Jesus,
As a rookie team, you are provided with parts in your KOP that are not provided to veteran teams. You can find this list on the KOP section of the First website. Many people are not aware that two KOP versions exist. Veterans are expected to use parts they have received in the past. You should have received two batteries I believe while veterans only receive one. |
Yes, its just I could not find it in any of the two lists. But i think eedoga had it right in saing that it did not include the gear assembly as part of the motor, and so it had a different id #, im pretty sure we found it in our list now, so thank you for your help.
Hopefully we can stop with the problems and get to work on the robot now ![]() Good luck ![]() |
