Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 22-01-2013, 19:33
JesusC JesusC is offline
FRC #4633
JesusC is an unknown quantity at this point
Gearhead mortor not in Kit?
Guys, my team has a very important question, that as a first year team, we dont know.
We got a few parts on our kit that were not on the list of parts that we got, so we are wondering if we can use it. Specificaly, a PG71 Gearmotor am-0914, because it was not in our kit, so....
Any help is appreciated Thx
Edit: We also have a few throttle motors with incorrect id #s, is that ok?
Edit: We Alsogot some motors that were not mentioned that are not gearhead
Unread 23-01-2013, 14:31
Undertones's Avatar
Undertones Undertones is offline
Drive Coach
AKA: Mac
FRC #4334 (ATA)
Undertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond repute
Re: Gearhead mortor not in Kit?
I don't even know how to begin to decipher this. Blatant self contradiction.
Formatting errors aside, I would assume that if you got it in the kit, you can use it.
And how exactly is it that you got a motor in your kit that wasn't in your kit?
This is making my brain hurt.
Team 4334, Alberta Tech Alliance, Calgary Alberta
Western Canada 2016 Champions
Western Canada 2016 Creativity Award
Utah 2016 Champions
Utah 2016 Excellence in Engineering Award
Western Canada 2015 Innovation in Control Award
Utah 2015 Champions
Western Canada 2014 Regional Chairman's Award
Western Canada 2014 Champions
Utah 2014 Judge's Award
Western Canada 2013 Champions
Western Canada 2013 Innovation in Control Award
IRI 2012 Champions
Archimedes 2012 Champions - "The Eh Team"
GTR East 2012 Highest-Seeded Rookie
GTR East 2012 Cooperition Award
GTR East 2012 Rookie All-Star
Unread 23-01-2013, 14:54
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
The motor listed in the KOP is the part number for the motor, not the part number for the gearbox assembly, so the short answer is, Yes you can use it. It took our team a long time to figure this one out also. There is some discrepancy though with using PG-71 gear assemblies from previous years because some of them are listed as having a different motor number than the one on the list. The way to fix that is to buy replacement motors for the gear head assembly.
Hope this helps more than it hurts.
Edoga
Unread 23-01-2013, 16:04
FRC #4633
Sorry for the brain hurting, i meant that we had a couple of motors that weren't in the list. Also, are we allowed to get motors that did not come in the kit of parts list, this is what i originally meant.
Sucks to be ESL... XD
Unread 23-01-2013, 16:27
eedoga's Avatar
FRC #2980
So if you look at Rule R32, It has a list of available motors for this year's robot. In the list is the motor am-2161 and am-2194. These are the motors used in the AM PG71 and AMPG188. Our understanding is that FIRST lists the part number for the motor, not the gearbox assembly. Your team can use any motor from the list in rule R32 in quantaties from the list in rule R32, you just have to include that in your Bill of Materials. Have fun shopping for motors!
Hope this settles things for you.
Edoga
R32
The only motors and actuators permitted on 2013 FRC ROBOTS include the following:
Table 4-1: Legal Motors
Motor Name
Part Numbers Available
Max Qty Allowed
CIM
FR801-001
M4-R0062-12
AM802-001A
217-2000
PM25R-44F-1005
PM25R-45F-1004
PM25R-45F-1003
PMR25R-45F-1003
PMR25R-44F-1005
6
BaneBots
M7-RS775-12
M7-RS775-18
M5-RS550-12
M5-RS550-12-B
M5-RS545-12
M5-RS540-12
M3-RS395-12
M3-RS390-12
4
AndyMark 9015
am-0912
4
Denso Throttle Control
AE235100-0160
4
VEX BAG and/or mini-CIM
217-3351
217-3371
4
AndyMark PG
am-2161
am-2194
3
Window Motors
262100-3030
262100-3040
Various from FIRSTŪ Choice
VEX 2-wire Motor 393
276-2177
Snow Blower Motor
am-2235
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
Unlimited
Drive motors or fans that are part of a motor controller or COTS computing device
Unlimited
Fans included in the 2013 Kickoff Kit, FIRSTŪ Choice, or as a Talon motor controller accessory
Unlimited
COTS servos with a maximum power rating of 4W each at 6VDC
Per the Servo Industry,
Servo Max Power Rating = (Stall Torque) X (No Load Speed)
Unlimited
Unread 23-01-2013, 16:47
FRC #4633
Thank you for your, this will definitly settle things, good luck and have fun.
Unread 23-01-2013, 22:18
Jesus,
As a rookie team, you are provided with parts in your KOP that are not provided to veteran teams. You can find this list on the KOP section of the First website. Many people are not aware that two KOP versions exist. Veterans are expected to use parts they have received in the past. You should have received two batteries I believe while veterans only receive one.
Unread 24-01-2013, 11:30
FRC #4633
Yes, its just I could not find it in any of the two lists. But i think eedoga had it right in saing that it did not include the gear assembly as part of the motor, and so it had a different id #, im pretty sure we found it in our list now, so thank you for your help.
Hopefully we can stop with the problems and get to work on the robot now
Good luck
