Go to Post All I wanted was a game hint.... :( - JohnBoucher [more]
Unread 23-01-2013, 16:37
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
Non-Colinear wheels
Wheels not in a line
Our team is using an 8WD with the two center wheels on each side dropped
Because of size constraints we are considering not putting the wheels in a line
from the top, it will end up looking like this
Front
Back
The vertical lines are our wheels and the dashes are how the spacing works
I've never seen a drivetrain like this
Does anyone know if any problems, with turning or otherwise, would arise from not having all four wheels in a line?
I can upload the CAD, or a better drawing if further clarification is needed
Thanks
Unread 23-01-2013, 16:48
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Non-Colinear wheels
Several teams have done this before, with no issues.
179 in 2005 and 2007
1889 in 2007
234 in 2007
All of these robots performed excellently and drove very well (I think there's three regional wins, a division finalist and a world finalist in that group).
I would caution you to double check everything against the bumper rules. There's nothing inherently wrong about that type of frame, but without the specifics it's hard to say exactly.
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
The closer together the outer wheels are the more they have to be dragged sideways to turn. It will work, but how well it actually performs is dependant upon how close together the outer wheels actually are. I would say that all the robots above have wheels close enough together that performace wouldn't be affected much at all. If you were thinking along those lines then you should be good.
Further apart = less turning scrub = better
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 23-01-2013, 17:00
FRC #2583
We are creating a chassis almost identical to those robots with the chamfered corners. if those worked then ours should be fine too
Thanks!
Unread 23-01-2013, 21:41
There should be no difference in performance between your offset design and an inline design using the same wheels and spacing. The dropped center wheels reduce turning friction and therefore minimize putting the drive motors into stall.
