Go to Post And (the video) didn't show how to do the "Charlie Brown". I still don't know how to do this... GAH!!!! - Elgin Clock [more]
Unread 23-01-2013, 16:37
ohdan56's Avatar
ohdan56 ohdan56 is offline
Commander-in-Chief
FRC #4284 (Highlander Robotics Fleet)
ohdan56 is an unknown quantity at this point
Cool Power Distributor flashing and ticking
At the site on the power distributor where we have a connection to one of our Jaguar MC, the board flashes red and it makes a ticking sound. There is not any power delivered to the Jaguar, as it is not lit up at all. Please advise on the cause of this problem and how we can address it. Thank you!
https://goo.gl/photos/8xZ9ixXRC3x14r5i7
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
DB
Unread 23-01-2013, 16:40
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Power Distributor flashing and ticking
Do you have a current breaker for that line you are trying to power? They look like huge black fuses that say 40A, 30A, and 20A on the top of them in big numbers and letters.
CTO/Head Programmer of Team 1710
Unread 23-01-2013, 16:42
ohdan56's Avatar
Commander-in-Chief
Yes, we have a 40A breaker in that line. We do currently have three other Jaguars functioning properly. So we suspect that a Jag is shot, but hope not Thanks.
- Thomas A. Edison
DB
Unread 23-01-2013, 16:43
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
It sounds like you have faulty wiring overdrawing and tripping a breaker.
Unread 23-01-2013, 16:46
ohdan56's Avatar
Commander-in-Chief
Any tell tale signs of faulty wiring? The four Jags were all wired together using the same schematic and material so we are confused. LOL cheers, thanks.
- Thomas A. Edison
DB
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The red light under the WAGO connector on the PDB is an indication of a short. The ticking sound you describe is likely the circuit breaker resetting itself after tripping from the short.
It could be a bad Jaguar (for example, metal debris caught inside the jaguar shorting things out), or it could be bad wiring.
2016: Lake Superior WFFA
Unread 23-01-2013, 16:54
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Try unplugging all the circuit breakers and powering up the system again. All should be quiet. Then plug the breakers back in one by one until you discover which branch circuits are causing the problem and unplug them immediately. Power the system back down and then check the wiring carefully on any branch circuits that resulted in a problem. Look carefully for reversed connections (input for output) or reversed polarity (positive for negative). Look for the raised markings on the plastic. Do not trust the wire color or screw colors as they may have inadvertently got swapped.
This is the zeroth day of the rest of your life.
Unread 23-01-2013, 21:19
The red light on the Power Distribution Board comes on to tell you there's something connected to the Wago terminals, but the breaker is either missing or tripped. The clicking is definitely the breaker tripping and resetting. I expect the breaker gets rather warm when this is happening.
Double- and triple-check the connections to the Jaguar. If nothing looks wrong, my suggestion is for you to remove the wiring on that branch and replace it along with the Jaguar itself. It's only two wires, right?
Unread 24-01-2013, 09:53
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Is the red light the one underneath the wires to the Jag? Im pretty sure this in effect means you've wired the voltage in to the voltage out on the Jaguar. You should fix that. Either that, or you wired the jag backwards (I think the breaker does that when that happens).
If it is the former, the Jag should be fine. If it is the latter, its not fine.
Unread 24-01-2013, 09:58
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
I would check and make sure that the jaguar isn't powered through the Motor side, check and make sure that the supply goes to the side marked with V+ and V-<<< not M+ and M-. My team hooked it up wrong on one of the jags, luckily it didn't damage anything.
2011 Record (11-3-0)
Unread 24-01-2013, 10:00
Glitch_94's Avatar
Glitch_94 Glitch_94 is offline
AKA: Harrison Shipp
FRC #3374 (RoboBroncs)
Glitch_94 is an unknown quantity at this point
This is what happened when one of our new wirers wired up the kitbot, it sounds like this is what's happening with you guys.
