Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Unread 21-01-2013, 16:09
nheft nheft is offline
FTC #0533 (Psichotics)
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
cRIO Imaging Issue
I tried re-imaging an 8-bay cRIO using my Windows 7 laptop with this year's Labview plus latest updates installed. Current version is v47. The imaging tool re-formatted the cRIO, set the IP address properly according to the team number, uploaded all the files, rebooted, and displayed a message that the cRIO was re-imaged successfully. But when the imaging tool re-scanned and re-discovered the cRIO, it did not display any status on the modules. Furthermore the cRIO would not communicate with the driver station. Got "No Robot Communication" but the "Robot" indicator i the diagnostic panel went green. The imaging tool did see the settings of the cRIO DIP switches.
I went on to re-image the cRIO from another Windows 7 PC desktop computer and everything went OK; modules were displayed as expected after re-imaging and the cRIO now communicates with the driver station. If I go back to the original laptop that gave me trouble, it now sees the installed modules, and I can deploy software using the "Run As Startup" menu item.
I was able to duplicate all of the above with two different cRIOs.
For now my workaround for this problem is to just use the desktop PC but I find it bothersome that the laptop does not re-image the cRIO correctly.
Any ideas?
Neil Heft
Team 533
Unread 22-01-2013, 15:57
Re: cRIO Imaging Issue
I've noticed that the imaging tool will not display the modules unless it is on the same class C network as the cRIO, even if the netmask of the computer is class A.
Additionally, having multiple network interfaces on the same network can confuse the imaging tool and driver station. Have you disabled unused network interfaces?
Unread 23-01-2013, 17:10
The laptop is 10.5.33.5 and the cRIO is 10.5.33.2. I have to check what I had the subnet mask set to on the laptop. I think I have it set it to 255.255.255.0 but I may have set it to 255.0.0.0. Can't check it until I get to the school tonight.
Once the cRIO has been properly imaged (I have another computer that works in the lab at the school), the laptop properly sees the modules and can deploy new software. That is why I think the laptop is incorrectly imaging the cRIO.
Unread 23-01-2013, 17:58
vintagecoke vintagecoke is offline
AKA: Keaton
FRC #4849 (Rock City Robots)
vintagecoke is an unknown quantity at this point
If I remember right, it needs to be 255.0.0.0. We got our successfully flashed on a Windows 7 laptop with that subnet mask.
Unread 24-01-2013, 21:57
litchbots litchbots is offline
FRC #1784
litchbots is an unknown quantity at this point
We are having exactly the same issue with the modules not showing up. Our cRio is a brand new 4 slot however. I am trying to image it with a Widows 8 laptop. When I get to school tomorrow I will try to image it with our old laptop and see if that will help. Thing is - the new Windows * laptop imaged the old 8 slot cRio not problem. This was my second day spent messing around with this new cRio. I was able to place Lab View code on it (no errors returned) using run as startup, but when I pull up the drivers station it does not recognize the cRio - no robot code. Any advice would be welcome. Could it be the drivers that came with the cRio? Should I re-install them?
Unread 25-01-2013, 07:18
Just to clarify, the laptop can't actually see the modules. The cRIO has to be imaged with a recent enough image to publish its module list to the imaging tool. Just graying out the image doesn't make that crystal clear, but that is one thing that can cause it.
Greg McKaskle
