Go to Post Ideally, you'll make sure your drive system can handle some Irritating Failures without them becoming Paralyzing Failures. - Billfred [more]
Unread 23-01-2013, 18:19
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Quation How to calculate the cylinder
How to calculate the retracted and extended length of a cylinder for our Robot if we use one cylinder for climping abore
Force = Pressure x cylinder area
I read FIRST Robotics Team 358, Hauppauge, NY Pneumatics for Newbies
Designing a Pneumatic Solution,
Leverage Force = Cylinder Force x sine(applied angle)
TEAM 1946-Tamra
Unread 23-01-2013, 18:37
pfreivald's Avatar
AKA: Patrick Freivald
Re: Quation How to calculate the cylinder
I'm sorry, is this a question?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 23-01-2013, 18:53
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I think he is asking how to find the LENGTH of the cylinder?
It should just tell you.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 23-01-2013, 18:57
yara92's Avatar
AKA: Mohamed
which cylinderi need to hang 70 kg robot , so to choose the right cylinder I need to get the job done?
TEAM 1946-Tamra
Unread 23-01-2013, 19:32
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Force = Pressure x Area
Force = Pressure in PSI x Area in Square Inches
Force = Pounds
So essentially when you multiply your PSI pressure by the area of the cross section of the cylinder you'll get the force in pounds.
Find how much force you need, in pounds, and go from there.
The cylinder with the larger bore (diameter) yields larger force.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 24-01-2013, 04:58
yara92's Avatar
AKA: Mohamed
I found This worksheet PneuMoment® Sizing Spreadsheet
http://www.bimba.com/Library/#Tools
assist in calculating PneuMoment's load carrying capabilities.
It performs the calculations shown under - "Application Consideration" for PneuMoment. The worksheet uses some of the calculated values to perform other Load carrying calculations.
Also This worksheet performs the calculations in Metric measures.
TEAM 1946-Tamra
