Go to Post It makes me wish I would have paid attention in my physics class... - jwallace15 [more]
Unread 20-01-2003, 18:33
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Serial Communication in C++
I'm having trouble finding resources on serial communication with c++ for the 3d dashboard program. I have finished coding the interface but I need the serial comm part... I heard that you might need to use MFC but I wasn't sure. Is there another way without having to create an MFC-based app?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 20-01-2003, 19:23
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: Serial Communication in C++
http://www.robbayer.com - just go to the how-to link, and there is a tutorial on how to get a serial communication set up w/o using MFC.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 20-01-2003, 19:58
Wow, I should have checked there first... thanks.
Unread 20-01-2003, 20:02
AKA: Eric Hansen
Yup, it helps if you download RoboCon (found on his site) also...it comes with some nifty functions and all.
Y!: synsoflife
Unread 20-01-2003, 20:32
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
A word of warning: ignore everything it says about mult-threading unless you know what you are doing. It's messy and can lead to some insanely difficult bugs.
Instead, follow RoboCon's example, as it is not multi-threaded and works just fine. Just make sure you are looking at the RoboCon source, and not ConSample as ConSample is MFC, but RoboCon is not.
--Rob
Unread 20-01-2003, 20:37
AKA: Eric Hansen
And MFC is confusing if you haven't really done any Win32 Programming (to me it was anyways). Multi-threading doesn't work all that well w/ Win32 anyhow.
Y!: synsoflife
Unread 20-01-2003, 20:52
I've done a bit of MFC and Win32 but I didn't really want to add MFC to the app if I could avoid it. It is complex enough having to use Direct3D... I'll try RoboCon to see how it works. Hopefully I can get this program working soon so I can upload the code to our team website (which I need to finish too...).
Unread 20-01-2003, 23:40
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've got a low overhead example of how to implement a software-based state machine that properly handles the dashboard data stream. If it'll help, you can find it on this page:
http://www.cvhsrobotics.org/resources.htm
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2003, 12:49
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
I've used my serial port to communicate with my Stamp- and PIC-controlled minions many times. The code in C++ is very easy. It's treated as a file. Just open "COMX" as the file and set a few permissions (where X is the port number)... its all in the MSDN serial communication sample program.
hPort = CreateFile ("COM4", GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, 0, NULL);
Then you'll want to look up the DCB structure to set all the cool baud rate, parity, and stop bit options. The COMMTIMEOUTS struct might help you out too. I've got a program that uses my serial port to send data (via my very own cobbled-together RS-232 radio transmitter) to one of my PIC robots. PM me and I'll send you the code.
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
organized way of communication with FIRST? archiver 2001 0 24-06-2002 04:20
Serial Port Communication White Paper rbayer Programming 87 14-06-2002 16:10
serial communication using c++ Malakili Programming 31 01-05-2002 15:51
