Go to Post I didn't know that Dean Kamen had 3 arms. - kevin.li.rit [more]
Unread 23-01-2013, 19:44
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Drawing on the live camera feed?
How would I go about drawing stuff on the live camera feed on the dashboard?
I'm programming in java.
“Be the change that you wish to see in the world.”
― Mahatma Gandhi
Unread 23-01-2013, 20:58
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Drawing on the live camera feed?
First things first, you have to create a SmartDashboard extension with a class extending WPICameraExtension. From there you have two options: either you can override the processImage() function and use WPIJavaCV or OpenCV functions to draw on the image, or you can override paintComponent() (if you choose the latter route, make sure to call super.paintComponent() in order to actually draw the feed image). The processImage() method is what I prefer, because if you're drawing based off of the information in the image, there's no need to keep that data around for paintComponent(). However, paintComponent() provides the flexibility of the entire Swing drawing API, so it's a matter of what you want to do with it.
I code stuff.
