Go to Post FIRST- its a pandemic in all our schools. - Akash Rastogi [more]
Unread 23-01-2013, 17:53
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Help, Robot turns wrong
We are using 4 CIMS in the KOP toughboxes, and our robot is turning incorrectly. We go forward alright, go backwards just fine, but no matter what PWM or jag we put our motors on, the robot will turn the opposite direction that we tell it to. We program in C++. Is there anything that can help us with this?
Unread 23-01-2013, 17:55
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Help, Robot turns wrong
Just swap the PWM cables from Left to Right and Right to Left.
Unread 23-01-2013, 18:12
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
If you are using tank drive, make sure your joysticks are ordered correctly on Setup tab of the Driver Station. Typically the left is Joystick 1 and the right is Joystick 2. With the robot disabled, click the trigger on one of the joysticks and you should see green asterisks display in the list. If you need to swap the joysticks, simply click and drag them into the right order.
If your joysticks are already in the right order or you're using arcade drive, check your PWM setup like Bill mentioned above.
Unread 23-01-2013, 20:31
Registered ConfUser
AKA: Mark McGivern
That didn't work. What did happen though was the robot's other axis was inverted, making the robot drive perfectly if you hold the joystick backwards.
Unread 23-01-2013, 21:00
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We've had this problem before in C++ I know how to fix it in LabVIEW... Basically you have to invert the control using a boolean. I do not know how to do it in C++ but it is something similar.
Another way to troubleshoot without code is to switch the polarity of the cables on the MOTOR side of the Jaguar/Talon/Victor and switch the PWMs if needed as well. You could make something along the likes of a truth table as well if that helps.
I would suggest switching the polarity of one motor, see if that fixes it and if not put it back to how you originally had it. Next you would try switching the polarity of the other motor.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 23-01-2013, 21:13
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
As always, follow the code.
Carefully.
With a piece of paper and pen.
Write down numbers, and how each line of code changes those numbers. From Joystick to Motor. Somewhere you have a sign going the wrong way, or more likely, not understanding what the joystick is giving you. This is a very common issue.
Have your electrical crew check their wires, to be sure, but this sounds like you have to check your code.
