Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-01-2013, 22:37
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: KoP ToughBox Mini and CIMs Problem/Solution
Originally Posted by Shu View Post
Turning the CIMs 180 degrees made a huge difference. You could literally see space between the CIM output gear and large cluster gear where before they were jammed together tight.
Yeah, odd, but thats what worked for us. We also made sure that we screwed the CIM down with it pulled as far to the outside of the gearbox as possible. Its the different between having gears grinding and having ~1mm of clearance.
Unread 24-01-2013, 00:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A caliper could solve this mystery.
Unread 17-03-2013, 05:23
dominik.daners's Avatar
dominik.daners dominik.daners is offline
Member
FRC #4729 (E.M.U (Experimental Mayhem Unit))
dominik.daners is an unknown quantity at this point
We had an issue with the 2013 KoP gearbox. One of the gearboxes had a gear contacting the output Hex shaft (inside the gearbox). We fixed it by filing the hex shaft down and had no further problems.
I attached an image (I think)
Could it be that the gearboxes are not always made to spec.?
Dominik Daners
Sydney, Australia
Unread 17-03-2013, 08:53
Does your camera have a macro setting?
