Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 23-01-2013, 22:52
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Robot code crashing after a while?
For some reason, when I run my code, it works for a while, then just randomly stops. I get a thing saying that there isn't any robot code running, but the little light on the DS says otherwise. I can switch modes and enable them with no issues, but still, the robot will not do anything. Aside from the crashes, everything works perfectly (Minus some potentiometer madness on our shooter tilt).
The source can be found here:
http://bitbucket.org/teammetalcow/ultimateascent
