Go to Post You must wear safety glasses at all times, so please bring them. - Don Wright [more]
Unread 23-01-2013, 22:52
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Robot code crashing after a while?
For some reason, when I run my code, it works for a while, then just randomly stops. I get a thing saying that there isn't any robot code running, but the little light on the DS says otherwise. I can switch modes and enable them with no issues, but still, the robot will not do anything. Aside from the crashes, everything works perfectly (Minus some potentiometer madness on our shooter tilt).
The source can be found here:
http://bitbucket.org/teammetalcow/ultimateascent
Unread 24-01-2013, 08:09
Re: Robot code crashing after a while?
Two things to check to figure out what is crashing:
1. Check the Free RAM on the Driver Station Chart tab, if this number is constantly decreasing to 0 while the robot is running your code leaks memory
2. Make sure NetConsole is enabled using he imaging tool, then open NetConsole, boot the cRIO (so you know Netconsole is working) then see if your code is reporting an exception when it crashes
3. If neither of the above is happening your code is likely hitting a semaphore deadlock. Running through the debugger may help locate it.
Unread 24-01-2013, 12:34
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
You might try disabling the watchdog, and see if that fixes it. If it does, then re-enable it and figure out where you're forgetting to feed the watchdog.
Unread 24-01-2013, 14:13
Thaddeus Maximus
AKA: Thad Hughes
1. Ill try this tonight. If it is a memory leak, how would I fix this? (What would even cause this?)
2. It is enabled (The Console Out switch, yes?) and I will check this tonight.
3. I disabled the semaphores we have and am not starting the second task I have, so I dont think I have any semaphores to deadlock with.
I'm not getting any watchdog errors or messages or lights or anything, but if Ruffles' suggestions don't work, I will do this.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 28-01-2013, 10:06
Thaddeus Maximus
AKA: Thad Hughes
I changed a few things and the code worked fine... I think I was allocating a resource twice.
Webpage
