Go to Post Are people allowed to go to the roboprom, or just our robots? - AmoryG [more]
Unread 23-01-2013, 23:58
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question LABVIEW WPI_PWMChannelcache.vi Error Message
Dear CD,
Upon exiting Labview, after building with the 2013 FRC Labview CD package with all 3 updates, I receive an error message every time I exit Labview. Searching through the Labview error log I see a file name of WPI_PWMChannelCache.vi. Is anyone else seeing the same Labview error reporting issue? Labview asks if I can send an error report and I am responding yes so the error message is being sent somewhere for review.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 24-01-2013, 07:48
Re: LABVIEW WPI_PWMChannelcache.vi Error Message
Does the error occur when you close the VIs and project first? Or is it when you exit with lots of stuff loaded?
Greg McKaskle
Unread 24-01-2013, 08:44
marccenter's Avatar
Smile Re: LABVIEW WPI_PWMChannelcache.vi Error Message
Greg McKaskle
Greg, I typically save/close down the project first and all the VIs. I'm not in the habit of leaving VI's open.
Here's a printout of the log. I went into Labview, used yesterday's build with no errors, Build again with no errors, save all project, close all project, exit and the following error report was generated.
Date: Thu, Jan 24, 2013 8:39:18 AM
#OSName: Windows (TM) Vista Home Premium Service Pack 2
#OSVers: 6.0
#OSBuild: 6002
#AppName: LabVIEW
#Version: 12.0f3 32-bit
#AppKind: FDS
#AppModDate: 10/04/2012 21:12 GMT
#LabVIEW Base Address: 0x00400000
<DEBUG_OUTPUT>
1/24/2013 8:40:33.423 AM
DWarn 0xD1EED773: Nonfatal insanity (0x00000080) detected in'WPI_PWMChannelCache.vi: BUILD__RT CompactRIO Target__{1164C992-0E95-4607-8FC5-875D62794830}'
e:\builds\penguin\labview\branches\2012patch\dev\s ource\panel\fpsane.cpp(1045) : DWarn 0xD1EED773: Nonfatal insanity (0x00000080) detected in'WPI_PWMChannelCache.vi: BUILD__RT CompactRIO Target__{1164C992-0E95-4607-8FC5-875D62794830}'
minidump id: ae4bcb8e-fc15-4d0a-9cca-7eace579b0c5
$Id: //labview/branches/2012patch/dev/source/panel/fpsane.cpp#1 $
</DEBUG_OUTPUT>
0x0069E583 - LabVIEW <unknown> + 0
0x10016460 - mgcore_SH_12_0 <unknown> + 0
0x00CAA7CF - LabVIEW <unknown> + 0
0x00D1CEEB - LabVIEW <unknown> + 0
0x00CCF287 - LabVIEW <unknown> + 0
0x00F78C6B - LabVIEW <unknown> + 0
0x00DD979D - LabVIEW <unknown> + 0
0x00D01EF0 - LabVIEW <unknown> + 0
0x00E404CA - LabVIEW <unknown> + 0
0x00D722EA - LabVIEW <unknown> + 0
0x00F78772 - LabVIEW <unknown> + 0
0x00F79353 - LabVIEW <unknown> + 0
0x005C1457 - LabVIEW <unknown> + 0
0x005C2D30 - LabVIEW <unknown> + 0
0x005C098C - LabVIEW <unknown> + 0
0x005C215B - LabVIEW <unknown> + 0
0x005C263E - LabVIEW <unknown> + 0
0x00649A4C - LabVIEW <unknown> + 0
0x00EC8D13 - LabVIEW <unknown> + 0
0x012DF9B9 - LabVIEW <unknown> + 0
0x012DB5C7 - LabVIEW <unknown> + 0
0x01271A3C - LabVIEW <unknown> + 0
0x00BFCE18 - LabVIEW <unknown> + 0
0x00BFE3A1 - LabVIEW <unknown> + 0
0x01633322 - LabVIEW <unknown> + 0
0x10E820F0 - <unknown> <unknown> + 0
0x01CD7181 - LabVIEW <unknown> + 0
0x00BDAC6E - LabVIEW <unknown> + 0
0x012753C1 - LabVIEW <unknown> + 0
0x0127B32B - LabVIEW <unknown> + 0
0x36809692 - mxLvProvider <unknown> + 0
0x368047A2 - mxLvProvider <unknown> + 0
0x3680F3B0 - mxLvProvider <unknown> + 0
0x368128CB - mxLvProvider <unknown> + 0
0x3682534B - mxLvProvider <unknown> + 0
0x0D6413E0 - <unknown> <unknown> + 0
*** Dumping Bread Crumb Stack ***
*** LabVIEW Base Address: 0x00400000 ***
#** sanity checking heap: "C:\Program Files (x86)\National Instruments\LabVIEW 2012\Targets\NI\RT\vi.lib\Rock Robotics\WPI\PWM\WPI_PWMChannelCache.vi"
#** sanity checking: "C:\Program Files (x86)\National Instruments\LabVIEW 2012\Targets\NI\RT\vi.lib\Rock Robotics\WPI\PWM\WPI_PWMChannelCache.vi"
#** compile: "C:\Program Files (x86)\National Instruments\LabVIEW 2012\Targets\NI\RT\vi.lib\Rock Robotics\WPI\PWM\WPI_PWMChannelCache.vi"
*** End Dump ***
<DEBUG_OUTPUT>
1/24/2013 8:40:34.205 AM
minidump id: d865676b-cb0a-405a-a9a3-1bc0fb218189
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
1/24/2013 8:40:34.385 AM
minidump id: ff0d1da8-4b57-4c8d-bf7a-1cfa5b8136e1
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
1/24/2013 8:40:34.386 AM
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
</DEBUG_OUTPUT>
*** End Dump ***
<DEBUG_OUTPUT>
</DEBUG_OUTPUT>
*** End Dump ***
Insane object at FPHP+114319E4, UID 2349, in "WPI_PWMChannelCache.vi": {graphics } (0x80): BigMultiCosmetic (COSM)
Insane object at FPHP+1143193C, UID 2298, in "WPI_PWMChannelCache.vi": {graphics } (0x80): BigMultiCosmetic (COSM)
Possible path leak, unable to purge elements of base #0
Marc Center
Unread 24-01-2013, 10:07
At least it's a "Nonfatal insanity", but only the men in white coats can help.
Unread 24-01-2013, 10:33
This is very helpful info. I'll put on my white coat.
Greg McKaskle
Unread 24-01-2013, 14:48
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
I'm not a LV expert, but I used to program with it, and an "insane" object is something that has gone very wrong, and it means that it didn't pass some sort of test. I've never seen an error like yours, where it says "nonfatal insanity", but if you changed anything on the wpi_pwmchannelcache vi, try changing it back. Also, you might want to try redownloading/installing the plugins.
Unread 24-01-2013, 17:29
No need to redownload at this point. I have put on my white coat and see that there is indeed a simple nonfatal insanity -- surely that terminology make sense to everyone, even if you don't work on the LV team?
In plain English, it means that the objects didn't pass their Integrity Test, also known as the Sanity test. The failure has to do with a few front panel objects that are left over from prior edits to the VI. A button on the front panel accidentally left behind two graphic objects that are no longer needed or used.
At this point, please ignore the notification. I believe you can even turn it off in the Tools Options dialog or at the bottom of the notification dialog. I expect this to be fixed in a future download.
Greg McKaskle
Unread 24-01-2013, 18:14
You can't fool me, there ain't no Sanity clause.
Unread 25-01-2013, 15:14
marccenter's Avatar
Greg,
Thanks for looking into this issue. I'm glad to find it's a little one.
Marc Center
