Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
Unread 24-01-2013, 02:44
android1254's Avatar
android1254 android1254 is offline
FRC #1254 (Tech Force)
android1254 is an unknown quantity at this point
Climbing
My team and I were throwing around ideas for climbing to get the frist level 10 points
And we're wonder if you even have to be hanging off the first bar to get 10 points.
Because picture for the prymind in the rules shows level 0= ground level 1= off grounf to top of bar. So we're wondering if it counts to just use one of the downward bars and drive up enough to not have any of the robot touching the ground.
Unread 24-01-2013, 02:46
Chris is me's Avatar
AKA: Pinecone
Re: Climbing
As long as you're not touching the ground you're at least in Zone 1. It doesn't matter what else you're not touching.
That said, "just" driving up the side of the pole is by no means a simple endeavor. I think almost any design that uses the horizontal bar would be simpler at the 10 point level.
Unread 24-01-2013, 02:52
Re: Climbing
No it not. Easy were just brain storming idea round it all. Thanks for the help and good luck to you this season.
Unread 28-01-2013, 12:30
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: Pyramid Climbing
Originally Posted by Akash Shah View Post
Is it legal to help assist another robot climb the pyramid when:
1: you climbed the pyramid already and are assisting another robot climb
2: both of the robots climb up the pyramid together
3: Assist another robot climb by letting them drive on top of you than let them climb.
And also, is it legal to just lift youself up to the first rung, touch the second, and than grasp yourself up to the third rung
Can anyone respond to this?
Please read the manual, Q&A, or numerous threads on this topic.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 28-01-2013, 12:34
Akash Shah's Avatar
Akash Shah Akash Shah is offline
FRC #4954 (4-H Palindrome Robotics Club)
Akash Shah is an unknown quantity at this point
Re: Climbing
I have read the rules and i can not find anything reguarding this topic. Like i know how you can climb the pyramid and how it has to be sequential and only one level at a time but nothing on helping another robot
FIRST Robotics Competition Team 4954
Co-Lead Mentor/Alumni
Drexel University Class of 2019
Unread 28-01-2013, 12:37
dcarr's Avatar
#HoldStrong
AKA: David Carr
Re: Climbing
It has been discussed here on CD...search is your friend :-)
For official answers, remember that the Game Manual and Q&A are your only sources.
Team 3309
Team3309.org
Unread 28-01-2013, 12:39
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
1. As long as the robot you are assisting does not invalidate the climb in some way (eg not touching the bars on the way up/touching more than 2 at once/ touching 2 non sequential), this should be valid. Q97 and Q107 in the official Q&A address this.
2. I'm not entirely sure what you are asking about here, could you try to be a little bit more specific about what you mean by "climbing together"?
3. This is legal only if one (or both) of the robots is (are) touching the pyramid this is per G33
For your last question, there is nothing that requires you must be supported by each rung however (you must, however, contact them), you must release the first rung before touching the third because otherwise you would have violated the requirement of only touching two consecutive levels at once.
But yes, please do look through the Q&A and Rulebook
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 28-01-2013, 12:42
Akash Shah's Avatar
Re: Climbing
Thank you very much. and what i mean by that is that can you latch you self onto another robot and than climb the pyramid. So can you pull a robot up with you?
Unread 28-01-2013, 12:43
Akash Shah's Avatar
Re: Climbing
But thanks for the advice
Unread 28-01-2013, 12:49
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Re: Climbing
As far as two robots climbing in tandem (i.e. one latched onto the other), I don't believe would a valid climb for the robot attached to the other unless they themselves climbed the bars as well. I don't believe one can attach to another and have that robot climb the pyramid. It'd be one diesel climbing mechanism to support that much weight however.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 28-01-2013, 12:52
pfreivald's Avatar
AKA: Patrick Freivald
Re: Climbing
Unless you are working with another team explicitly for the purposes of designing group-climbing robots, I wouldn't expect any team to trust you to lift their robot... Because if something goes wrong, you can end their competition season in under a second.
Last year you could hardly count on teams to balance on a bridge with you -- I'd be terrified of trusting another team to lift us five feet in the air.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 28-01-2013, 14:57
Akash Shah's Avatar
Hahaha. Well thanks for the advice guys
Unread 28-01-2013, 15:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Climbing
Work out the engineering mechanics equations (force, traction, and torque) related to 'just driving up' the pole. I did, and we immediately ruled it out because it appeared unfeasible (but not impossible).
Unread 28-01-2013, 15:58
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Climbing
Originally Posted by MetalJacket View Post
This would seem a little sketchy based on G29
While the latching would most likely not be damaging, it would most definitely be deliberate.
A more thorough reading of G29 may be in order:
Deliberate or damaging contact with an opponent ROBOT on or inside its FRAME PERIMETER is not allowed.
I don't know about you, but I most certainly don't want to help my opponent climb my pyramid.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 28-01-2013, 16:30
AKA: Jesse Gibson
Team Role: CAD
Re: Climbing
Sorry, I can't believe I didn't see that. It seemed a little odd that they would say it was illegal to contact within frame perimeter but say that it was fine to lift your partners (in the Q&A). I think I'll just delete that post.
2011 - Logomotion
