Go to Post This our big chance to spread the word and change the culture, let's not waste it. So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 23-01-2013, 01:21
bfk bfk is offline
FRC #2521
bfk is an unknown quantity at this point
Re: Full Court shot
Originally Posted by dtengineering View Post
Before I go all "safety mode", let me just point out that is a very cool shot and I'm pretty impressed. Okay... now its time for the tech inspector in me to express a concern...
I know this is just a prototype, and that you're probably already planning a safety shield for this shooter, but I think teams should be aware that not only are these wheels not designed to spin at high RPM, but that they store a significant amount of finger-ripping energy when they do.
It is much easier to build safety shields in to your design than to add them as part of tech inspection!
Thanks,
Jason
Definitely a design consideration. I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way.
Unread 23-01-2013, 01:33
bfk bfk is offline
FRC #2521
Re: Full Court shot
Originally Posted by Brandon_L View Post
That looks like the AM Pneumatic wheel. Were also using that, but it wobbles insanely. How did you manage to fix that? Yours looks pretty stable.
Basically, first of all make sure your motor mount is very stable.
Make sure the hub is perfectly centred on the wheel. We used some thin grippy material between the wheel and the hub to prevent it slipping. Make sure all six bolts are tight.
Then find a piece of something that can fit in the hole in the hub and suspend the wheel like a plumb bob. You'll see it list a lot to one side or the other. The weight of the fill tube leaves it way off balance. Attach weights to the wheel until it balances as perfectly as you can get it. Make very sure that the weights are securely attached, these wheels are really moving fast and a couple of grams at that speed will do serious damage. See Jason's post above.
Then everything is great and hopefully your team-mates will have developed the world's best climber while you were working on the shooter. That part didn't work out that way for us, but a guy can dream.
Unread 23-01-2013, 09:39
TeamUpNext3528's Avatar
TeamUpNext3528 TeamUpNext3528 is offline
FRC #3528 (Team UpNext)
Team Role: Driver
TeamUpNext3528 is an unknown quantity at this point
Re: Full Court shot
WoW! That was awesome! Our team is going for the same approach. We are wanting to shoot full court shots. But that really depends if our shooter is accurate enough.
And I do agree, there could be air flow getting in the way of those long shots depending on where the regional is.
Unread 23-01-2013, 23:30
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
Re: Full Court shot
Any tips on balancing the wheel?
Unread 23-01-2013, 23:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Full Court shot
Our team stuck a couple of long screws to the inside of the wheel opposite the valve. It seems to be working so far...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 24-01-2013, 01:03
Re: Full Court shot
Here's our full court shot - http://www.youtube.com/watch?v=rNT5c...Jchc5w&index=5
Unread 24-01-2013, 06:25
rai337 rai337 is offline
FRC #1574 (Miscar1574)
rai337 is an unknown quantity at this point
Re: Full Court shot
Originally Posted by Akash Rastogi View Post
what wheel you used? we've been trying pneumatic wheels and rubber wheels and the pneumatic wasnt stable, while the rubber didnt have much power..
Unread 24-01-2013, 12:13
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Re: Full Court shot
Thanks,
Jason
This is definitely a valid point. One our team has considered as well. We are not using the AM Pneumatic Wheel but we attached "Shrapnel Guards" as far around our wheels as we could, so if the wheels wear out and fragment they won't fly out and hit anyone.
Unread 20-02-2013, 14:40
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: Full Court shot
Don't have a video yet but we were shooting above 90 percent into the 2 point goal from the feeder station. And able to get one load of 4 Frisbees every 10 to 15 seconds
Unread 20-02-2013, 15:17
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Re: Full Court shot
Team 4061 went to a tire store and got stick on wheel weights.
The valve stem was the heavy spot so we added 2 wheel weights at 120 and 240 degrees from the valve stem. This gave 3 points of weight the valve stem and the stick on weights. We had to use 1/4 oz at the 2 points. This worked very well to rid vibration.
