Go to Post 32% of the teams in any division will be or could be in eliminations. And any one of those could be YOU. If you aren't ready, you will be eliminated. If you are ready, you greatly increase your chances of winning. - EricH [more]
Unread 23-01-2013, 16:18
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Rules
Is there a rule against having something else other than you wheels touching the ground at the beginning of the match? say for instance, for our pick up system, we are planning on bending lexan on the floor, would they say that we can't have that? that it would damage the field?
Unread 23-01-2013, 16:19
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: Rules
If you anticipate it damaging the field, I think you answered your own question.
Otherwise, I don't know of any rules that specify that "wheels" must touch the ground. What if you don't have "wheels" ?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 23-01-2013, 16:21
rwkling1's Avatar
Re: Rules
we are not going to damage the field, it is just the fact that THEY think it's going to damage the field, but it wont
Unread 23-01-2013, 16:31
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Rules
You do have to convince the inspectors that it will not damage the field. Once that is done, you should be good
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 23-01-2013, 16:33
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Rules
We had lexan on the pick up of our Logomotion bot that we slipped under the game pieces to pick them up and no inspector questioned us.
Unread 23-01-2013, 16:39
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Rules
If inspectors think it will damage the field, you need to fix your robot until they're satisfied. You can't even go to practice matches if they have told you about a significant risk of field damage (or danger to people or other robots). I suggest you make sure your design looks as safe as you believe it is.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 23-01-2013, 16:45
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Rules
Wheels? Where we're going, we don't need wheels.
Unread 23-01-2013, 17:10
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Re: Rules
Made my day. Futuristic FRC games now running through my head with flying robots equipped with water cannons to shoot at targets with.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 23-01-2013, 21:39
Re: Rules
There is no rule about contact with the field surface except that there can be nothing that extends past the Frame Perimeter in the Start Configuration. Although inspectors will check, the refs will be watching. Extending past the Frame Perimeter in Start Configuration carries some obvious penalty.
Unread 24-01-2013, 08:11
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Rules
Remember that the tower areas have a carpet on top of the main field carpet. It might be enough to pick at your lexan when driving up onto it. While that may damage the field (illegal), it may also trip your robot (not illegal, but a problem for you).
We had this problem a couple of years ago, so it's something we look for.
When I was a kid Popular Science magazine promised me that by now.
