Go to Post This exercise in thanking the hand that teaches you brought to you by the Unsung FIRST Heroes Award. Have you thanked your mentor lately? - Amanda Morrison [more]
Unread 23-01-2013, 07:12
yarudl yarudl is offline
FRC #0578
yarudl is an unknown quantity at this point
Torque Rating
I'm looking at gearsets and I came across a set that doesn't have a torque rating listed. Does anyone know how much torque the worm gears on mcmaster-carr can handle?
Thanks,
Yarudl
Unread 23-01-2013, 07:53
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Torque Rating
Post some part numbers, and we can see if we can give you a hand.
If you are looking for a good worm gear box, may I recommend looking at these:
http://www.andymark.com/product-p/am-0917.htm
Unread 23-01-2013, 08:36
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Torque Rating
We're looking at McMaster-Carr worm drive:
Worm (screw) 57545K527
Worm gear 57545K515
These are 12 pitch, 14.5 degree pressure angle, cast iron, and would give a reduction of 30:1.
The am-0917 has impressive ratings for plastic gears. If I read the drawing correctly, it looks like it can only attach to 1 CIM motor. We were hoping to use two.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 23-01-2013, 08:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Torque Rating
Seat of the pants say you will not break the Mcmaster Carr gear sets with any first legal motor. The issue is worm gears have sliding friction. Under high loads, this can really be significant. The more you load them up the better the lubrication needs to be.
Unread 23-01-2013, 09:05
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Torque Rating
If you can use two of these gearboxes, then you can use two motors.
Unread 23-01-2013, 09:11
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Torque Rating
Here are some example calcs that should help you rate the cluster you are looking at:
http://cr4.globalspec.com/thread/110...r-Calculations
here is a link with better/more in depth calculations:
http://www.roymech.co.uk/Useful_Tabl...orm_Gears.html
Unread 23-01-2013, 09:45
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Torque Rating
Problem is these have been out of stock since at least last week, when I first checked.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
MrForbes's Avatar
AKA: Jim
Re: Torque Rating
Make your own...you can buy the gear set at places that sell replacement parts for Chamberlain garage door openers.
Unread 23-01-2013, 09:57
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Torque Rating
This is heavy, and inefficient, but it is cheap, and is pretty durable:
http://www.harborfreight.com/2000-lb...inch-5798.html
it is also a 40:1
Unread 24-01-2013, 10:16
FRC #0578
Re: Torque Rating
So after contacting McMaster I did get a response on the torque ratings. This is what I got: It's a little blurry but it says at 1800 RPM it can take 340 in lbs of torque.
Thanks,
Yarudl
Unread 24-01-2013, 10:18
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Re: Torque Rating
You'd be able to lead them up to the material's yield strength. Most of the force on a worm gear would come from force along it's axis coming from the backdriving of the output gear which would be one mode of failure. As previously mentioned with a heavily loaded gearset, you'd also encounter a lot of friction and this would cause your motors to work harder so make sure you lubricate those gears!
The wormbox is made of nylon and while nylon will yield at less stress than steel, it wears less and a nylon gearset will also have less friction. In this application where you're unsure whether or not your gearset will hold up under loading, you may consider it safe to go with the McMaster parts.
As for a more direct answer, it's difficult to calculate how much torque they can withstand without detailed calculations. The 57545K527 worm is made of steel and it should be able to handle the loads fine. If you have doubts, I'd recommend to fail early and fail fast, or just email McMaster Carr asking.
Edit: I see you already emailed them! Fantastic. 340 in*lb or ~38.41 N*m isn't that much. How much load are you placing on the output of the gearbox?
Unread 25-01-2013, 08:44
FRC #0578
Re: Torque Rating
We're having the whole robot on a pulley connected to this. so about 170 in-lbs.
Thanks,
Yarudl
Unread 25-01-2013, 10:01
Re: Torque Rating
Where did you get the 170 in-lb figure from? What's your pulley diameter and how much load are you lifting?
Unread 25-01-2013, 10:10
FRC #0578
Re: Torque Rating
We're using a 2" diameter pulley and it's lifting the weight of the robot. We overestimated the load to be safe.
Thanks,
Yarudl
