Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 24-01-2013, 12:18
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Auto
G05 states that the robot must be in contact with pyramid, so does that mean as long as one wheel is contacting the carpet outside the auto zone you can recieve 3 frisbees at start up? Or because you are not fully supported by the non auto zone carpet you would only recieve two frisbees?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 24-01-2013, 12:31
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Auto
I think you mean G06.
Originally Posted by G06
TEAMS may preload White DISCS in or on the ROBOT before the MATCH.
If the ROBOT is in contact with any carpet outside its AUTO ZONE, the ROBOT may preload up to three (3) DISCS.
Otherwise, the ROBOT may preload up to two (2) DISCS.
Violation: If the situation is not corrected before the start of the MATCH, TECHNICAL FOUL per extra preloaded DISC in or on the ROBOT.
As my interpretation, contact is defined as "some part of your robot touching", thus, if a part of your robot is behind the Auto line at the back of the Pyramid AND you're touching the Pyramid, you can receive 3 DISCS. There is no line that states you must be fully supported behind the line. For a definitive answer, I suggest you submit this question to the GDC Q&A.
Academic Student (Forever)
Unread 24-01-2013, 12:38
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Auto
3.2.2.2 G06
A. If the ROBOT is in contact with any carpet outside its AUTO ZONE, the ROBOT may preload up to three (3)
DISCS.
B. Otherwise, the ROBOT may preload up to two (2) DISCS.
in or on the ROBOT.
Looks like CalTran answered just before me ... I added some emphasis to the G06 rule above.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 24-01-2013, 13:46
AKA: Garty
Re: Auto
Thanks for the clarification!
- Dr. Seuss
