Re: Updating Jaguar Firmware for CAN
I fixed the problem with not being able to connect with the COM port by trying a couple different laptops. The serial to CAnN cable came with the kit of parts and the USB to serial cable was ordered off amazon. This is the product: http://plugable.com/products/pl2303-db9. Yes we're using a CAN terminator we made it using instructions made by Team 1718 online. We're using a single black jag right now. I haven't tried connecting to multiple jags yet and I figured I would try the black jags before working on the old tan ones. This is what the BDC-COMM screen looks like right now. Thanks!
Solved this problem on my end, electrical has just informed me they did the cabling wrong.
Always makes you feel a little better when it's not your fault ![]() |
CosmicCricket, can I ask you what you did to solve the problem on your end. How did you get rid of your blinky yellow lights?
After you assign an ID, the lights should blink a certain number of times depending on your ID. If it's happening beforehand, you should look at your cabling.
Our cable actually tested fine on a voltmeter, but we found out that whenever we pushed it into a port one of the wires would end up slightly out of place, which messed the entire thing up. |
