Go to Post I always say find what works best for your team, for your given situation. Why should we rely on someone else to tell me what will work best for our situation? - JVN [more]
Unread 24-01-2013, 13:16
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Can I use a Spike to control a BaneBots motor?
Hello,
I was wondering if there's any reason why I shouldn't use a Spike to control a Banebots motor? (Since until today I only saw Spikes connected to Pneumatic Compressors, nothing else)
Thanks!
Unread 24-01-2013, 13:20
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Can I use a Spike to control a BaneBots motor?
Originally Posted by Itamar View Post
Hello,
Thanks!
Per Table 4.4 of Rule R52, yes and no, you can use a Spike to control a Banebot. Depends on the specific Banebot. Might I inquire as to what you need a Banebot at full power all the time for?
Academic Student (Forever)
Last edited by CalTran : 24-01-2013 at 13:22. Reason: Missed certain motors in my blanket statement. Fixed now.
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
R52
But beyond legality, you should consider the application for the motor. Is speed control desired? Do you ever want to run it at less than the battery voltage?
Unread 24-01-2013, 13:35
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
You can do it but I would not recommend it. Last year, we started out using Spikes on Banebot RS550's running our conveyors and were continually blowing fuses. You are only allowed to use the resettable fuses with a compressor and nothing else connected to a Spike. We ended up switching over to Victors and did not have any more issues.
Unread 24-01-2013, 17:39
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Only do it with light duty loads. The fuses won't hold up if you try to do any heavy-lifting with it.
Unread 24-01-2013, 18:10
Itamar's Avatar
It turns out the motor we're using is RS540, so using a Spike is out of the question.
The motor is used to run our pickup system, and it works best running full speed. Anyway, even if it was legal I wouldn't take my chances to run into the problems mentioned by Shu and cgmv123.
