Go to Post … it’s all good as long as the kids are inspired. - AdamT [more]
Unread 24-01-2013, 18:06
Lc_1850 Lc_1850 is offline
FRC #1850
Lc_1850 is an unknown quantity at this point
Any feedback would be Super helpful (Windriver Error)
"Downloading to robot..." has encountered a problem
Unable to connect to robot using IP: 10.18.50.2:21
This is the error I'm receiving, and I'm pretty sure this is the right I.P. address.
Unread 24-01-2013, 19:01
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Any feedback would be Super helpful (Windriver Error)
I'm assuming this is from the FIRST Deploy option in Workbench. You might try two things...
1. Try pinging the robot using the command "ping 10.18.50.2" to verify the connection.
2. Try turning off the Windows Firewall as a quick test to see if it starts getting through to the robot in that case.
Brad
Brad Miller
Robotics Resource Center
Unread 24-01-2013, 20:01
FRC #1850
Thank you for he help, but I corrected the issue. The problem was that my cpu I.P. was changed. Thanks for the help anyway
