Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 24-01-2013, 21:25
3044smike's Avatar
3044smike 3044smike is offline
FRC #3044
3044smike is an unknown quantity at this point
Question PWM to CAN switch
does anyone know how to do this via programming (perferably in java), my team has been having some problems.
Team 3044 Ox: BE4
http://www.team3044.com/
http://www.usfirst.org/frc
I have a image of a DVD REWINDER
Unread 26-01-2013, 17:19
CosmicCricket CosmicCricket is offline
FRC #2517
CosmicCricket is an unknown quantity at this point
Re: PWM to CAN switch
Programming-side, working with CAN should not be too different. Make sure you are declaring your jaguars as CANJaguars, and make sure your ID numbers match up with those in your code.
Unread 27-01-2013, 00:12
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
That depends on what mode you want the Jaguar be in. If you are doing default mode, then it is pretty simple. If, however, you are doing any of the close-loop modes, you need to call different functions to initialize the Jaguar correctly. For example:
        m_Motor1(CANID_MOTOR1_JAG, CANJaguar::kSpeed);
        m_Motor1.SetSpeedReference(CANJaguar::kSpeedRef_QuadEncoder);
        m_Motor1.ConfigNeutralMode(CANJaguar::kNeutralMode_Coast);
        m_Motor1.ConfigEncoderCodesPerRev(SHOOTER_ENCODER_PPR);
