Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 18-01-2013, 14:26
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
pynetworktables: python wrappers for NetworkTables
The RobotPy project has a new github repo that contains SIP-based python wrappers for NetworkTables that will work on your PC. Currently only the server (robot) side of the wrappers work, but in theory the client side should work with a bit of patching. I won't be able to work on fixing that until next week.
https://github.com/robotpy/pynetworktables
Feedback and patches welcome.
Unread 23-01-2013, 17:52
virtuald's Avatar
RobotPy Guy
Re: pynetworktables: python wrappers for NetworkTables
Ok, found the client bug in WPILib. The python wrappers now will do server and client mode, and there are samples included with the source code that demonstrate this functionality.
For the bug, see http://firstforge.wpi.edu/sf/go/artf...3589813396 74 .
Unread 24-01-2013, 22:24
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
I am curious if I could do this with Python 2.7 (I know SIP supports it)?
I ask because I was thinking about using SimpleCV for vision and it would make life much easier.
Unread 24-01-2013, 22:49
virtuald's Avatar
RobotPy Guy
I haven't tried it, but I don't have any reason to believe it wouldn't work.
Unread 25-01-2013, 19:07
Use the following commands to build pynetworktables. Do the following on
Windows:
set ROBOTPY=c:\path\to\robotpy\src
What do you mean by src
Why is this different than the unix version?
Unread 25-01-2013, 19:13
virtuald's Avatar
RobotPy Guy
Windows:
Read it out loud. It is not meant to be a literal path. It is the path to the robotpy source directory. It is different from the unix one by accident.
Unread 25-01-2013, 19:21
I did read it out loud being different is what confused me. Thanks I got it.
Unread 26-01-2013, 02:42
virtuald's Avatar
RobotPy Guy
Excellent. I've changed the documentation too, so it doesn't confuse anyone else
Unread 02-02-2013, 10:31
tkbletsc tkbletsc is offline
FRC #4561
tkbletsc is just really nicetkbletsc is just really nicetkbletsc is just really nicetkbletsc is just really nice
Rookie team here, very confused.
First, is this necessary to use SmartDashboard from Python?
Second, RobotPy has a simple installable on firstforge which we used. Is there something comparable for this pynetworktables, or do I need to build from scratch?
Third, if I do have to build it, do I need to build+install robotpy from source too, or does the pynetworktables build process give me something I add on to my robotpy install?
Thanks!
Unread 02-02-2013, 12:59
virtuald's Avatar
RobotPy Guy
This allows you to use NetworkTables/SmartDashboard from python on your PC. This code does not run on the Robot.
This code would be useful if you had something on your driver station or programming laptop that wanted to communicate with your robot code via NetworkTables, or if you were running unit tests on your PC (using fake-wpilib) that use SmartDashboard.
There currently are no binary distributions of pynetworktables, so if you wanted to use it, then you would need to compile it yourself.
Unread 03-02-2013, 06:15
FRC #4561
Ah, so smart dashboard should work from stock robotpy without modification? ... then I have some debugging to do... :-)
Thanks!
Unread 19-02-2013, 19:38
I am trying to build the network tables using the instructions on a ODROID-U2 ubuntu - linaro 12.3
linaro@linaro-ubuntu-desktop:~/pynetworktables$ ROBOTPY="/home/linaro/robotpy/" python setup.py build
running build
running build_ext
building 'pynetworktables' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablescmodule.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablescmodule.o
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for Ada/C/ObjC but not for C++ [enabled by default]
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesEntryValue.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesEntryValue.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesSmartDashboard.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesSmartDashboard.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesSendableChooser.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesSendableChooser.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNamedSendable.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNamedSendable.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesSendable.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesSendable.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesWriteManager.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesWriteManager.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesTransactionDirtier.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesTransactionDirtier.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesOutgoingEntryReceiver_NULL_t.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesOutgoingEntryReceiver_NULL_t.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntry.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntry.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesOutgoingEntryReceiver.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesOutgoingEntryReceiver.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesTableListenerManager.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesTableListenerManager.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesStringArray.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesStringArray.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNumberArray.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNumberArray.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntryTypeManager.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntryTypeManager.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntryType.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNetworkTableEntryType.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesBooleanArray.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesBooleanArray.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesArrayEntryType.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesArrayEntryType.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesComplexEntryType.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesComplexEntryType.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesArrayData.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesArrayData.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesComplexData.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesComplexData.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesPeriodicNTThread.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesPeriodicNTThread.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesNTThread.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesNTThread.o
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/home/linaro/pynetworktables/src -I/home/linaro/pynetworktables/sip -I/home/linaro/robotpy/Packages/wpilib -I/home/linaro/robotpy/Packages/wpilib/WPILib -I/usr/include/python2.7 -I/usr/include/python2.7 -c build/temp.linux-armv7l-2.7/sippynetworktablesDefaultThreadManager.cpp -o build/temp.linux-armv7l-2.7/build/temp.linux-armv7l-2.7/sippynetworktablesDefaultThreadManager.o
/home/linaro/robotpy/Packages/wpilib/WPILib/networktables2/thread/DefaultThreadManager.h: In member function ‘virtual NTThread* sipDefaultThreadManager::newBlockingPeriodicThread (PeriodicRunnable*, const char*)’:
/home/linaro/robotpy/Packages/wpilib/WPILib/networktables2/thread/DefaultThreadManager.h:23:20: error: ‘virtual NTThread* DefaultThreadManager::newBlockingPeriodicThread(Pe riodicRunnable*, const char*)’ is private
build/temp.linux-armv7l-2.7/sippynetworktablesDefaultThreadManager.cpp:68:69: error: within this context
/home/linaro/robotpy/Packages/wpilib/WPILib/networktables2/thread/DefaultThreadManager.h: In function ‘PyObject* meth_DefaultThreadManager_newBlockingPeriodicThrea d(PyObject*, PyObject*)’:
build/temp.linux-armv7l-2.7/sippynetworktablesDefaultThreadManager.cpp:95:100: error: within this context
build/temp.linux-armv7l-2.7/sippynetworktablesDefaultThreadManager.cpp:95:143: error: within this context
error: command 'gcc' failed with exit status 1
Any Ideas?
Thanks,
Paul Davis
Unread 20-02-2013, 00:44
virtuald's Avatar
RobotPy Guy
You need the current git head of RobotPy to compile pynetworktables. RobotPy uses git submodules now, and if you don't check it out correctly then pynetworktables will not compile for you.
git clone https://github.com/robotpy/robotpy.git robotpy
cd robotpy
git submodule init
git submodule update
I've gotten it to work on Windows and Linux for Python 2 and 3.
Unread 20-02-2013, 01:38
That explains allot. Thanks
Unread 21-02-2013, 11:27
cd robotpy
git submodule init
Thanks that worked.
