Go to Post quick everyone find everything in the whole world that sells for $125 so we can get an edge on our building 2 days before kick off.....ready...go! - Greg Needel [more]
Unread 24-01-2013, 17:02
AutoBotAM AutoBotAM is offline
AKA: Christian Reese
FRC #2077 (Laser Robotics (Laserbots))
AutoBotAM is an unknown quantity at this point
Test Mode and Driver Station?
I've noticed a function in SimpleRobot called test(), commented that it is called once every time "test mode" is entered. How do I enable test mode in the driver station? All I see are teleop, autonomous, and practice modes.
"Mecanum drivetrains, like every other, have advantages and disadvantages, but some of the disadvantages being discussed here are overstated and/or misinformation." -buchanan
Unread 24-01-2013, 17:05
Re: Test Mode and Driver Station?
Then you might have the wrong Driver Station.
On the Diagnostics tab what does it list for DS version (below the USB Devices list of the Joysticks/IO/Kinect)?
Unread 24-01-2013, 17:09
I'm not at our programming laptop at the moment, I will check tomorrow. But the image you posted does look different than our driver station, I suspect I need to install the new 2013 update from NI. Thanks.
Unread 24-01-2013, 17:11
Can't hurt to install it twice.
Unread 24-01-2013, 23:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Just a word of warning: uninstall the tools from last year before installing the software from this year. Apparently there were a few teams that had issues installing the new driver station over the old one.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 25-01-2013, 18:22
Installed the update, works like a charm. Thanks guys.
Anyone reading this: if you're a Java team and want to use SmartDashboard, you have to enable Java in the Driver Station settings, then it will work.
