Go to Post just watch out for the evil, robot devouring ghosts - Mr. Pockets [more]
Unread 24-01-2013, 22:00
hedgeberg hedgeberg is offline
FRC #1389
hedgeberg is an unknown quantity at this point
Powering Jaguars with 24 volts
Hey guys
My team wants to use 18v Banebots 775 motors.
As far as we can tell, we can't get anywhere near the potential of these things with our Jaguars being powered using 12 V. How best can we output at the necessitated 18v?
We've been looking at step up transformers, but those are both expensive and heavy, and we need to find some way to reach the maximum power output of these motors.
We're climbing to the top of the pyramid, and we need enough power to get the robot up that thing.
So yeah, how can we step up voltage for our Jaguars? Or, if we can't step up the voltage, is there a way without stepping up the voltage to power the 18 volt motors at full capacity?
Thanks!
Unread 24-01-2013, 22:04
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
Re: Powering Jaguars with 24 volts
Be sure to read Rules R32 and all under 4.1.8. I don't believe any ways of stepping up voltage to motors or servos are legal for FRC.
Unread 24-01-2013, 22:05
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
No component on the robot can exceed 12 volts. Therefor it is unnecessary to need to power an 18 volt motor at 18 volts.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 24-01-2013, 22:07
FRC #1389
Yeah, I probably should have read up on that. I figured that might be an issue.
Thanks guys.
Unread 24-01-2013, 22:10
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I might be wrong, but what about the 24V solenoids?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 24-01-2013, 22:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The cRIO runs on 24 volts, and the solenoid breakout can be powered by 24 volts or 12 bolts, depending on the solenoids you need to power.
Motor controllers, however, cannot.
Unread 24-01-2013, 22:29
Those are allowed to be run at 24V, via the PDB's 24V board. Same place the cRIO gets power from.
The relevant rules are R39, R43, and R44.
For the RS775-18, the BaneBots site does list some of the specs at 12V--take a look at those.
Unread 25-01-2013, 00:06
Sorry, should have specified motors and motor controllers. The above posts are correct though, the cRio does run at 24 volts as do some of the solenoids.
Unread 26-01-2013, 14:48
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
The power supply that provides the 24 volts for the cRIO is only good for a few amps. It would not supply enought current for a motor.
-Hugh
Unread 26-01-2013, 19:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
For future reference though, the BLACK Jaguar is specified to run from 5.5V-30V DC. We had an off season project that required 24V, and the BLACK Jaguar fit the bill.
The GRAY Jaguar is only specified to run up to 15V.
Rule wise though, no.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
